just rebuilding node.and I dont have the network connection hooked up. I presently have a node running on my network and didnt want to start messing around.
here’s the issue , I’m getting a screen saying [some number . more] retire_capture_urb: 4999 callbacks suppressed.
is this a ET call home error since i dont have the nic connected and it should correct its self when I take it back to the site and hook it up to the router at the site?
thanks
bruce
ve3 bv 53554 and 53965 (is the rebuild one)
I may have found it…changed usb port for interface ,so far so good…
let it burn in for a couple days and see if issue comes back
also checked the power supply to the PI as in other posts…
kepp you posted
ve3bv
