Garmin GPS18x no longer compatible with RTCM
Hi folks,
Wanted to get this out to you before anyone else bought one thinking they would work (since this model is specifically called out in the RTCM docs).
When using a GPS with a Micro-node RTCM for voting, you need to find one that has a 5 volt Pulse-per-second output. The Garmin lines that is recommended (GPS 18X, 18X lvc, etc…)
NO LONGER do this!
This is what I got back from Garmin:
Mr. Cizek,
I was just told there was a design change with the GPS 18x LVC. The PPS signal voltage is now 3V. This was something we were not told until today. We will be making the changes to the online Technical Specifications to reflect this change.
I do apologize for the inconvenience. This was a change we were not informed of.
So this line of GPS’s will NOT work with an RTCM any longer. Talking to Mark at Micro-node, there is a voltage divider in the RTCM dropping the 5 volt to 3.3 volt to be compatible with the CPU. With only 3 volts on the incoming line, there isn’t enough making it to the CPU to trigger a state change and you will get “PPS Timeout” errors and be unable to achieve GPS lock.
I am not sure what kind of timing skew a level converter would introduce, so it’s probably a better bet to just get a GPS that has a 5 volt line (Trimble Thunderbolt or the similar).
There may be a possibility of removing or modifying the voltage divider inside as well, but without schematics, and unless you have SMD capable gear, it’s unlikely that that is a good solution.
Just wanted to let folks know so they don’t repeat the brain damage I just went through figuring this out :slight_smile:
James
KI0KN
Hello James,
SparkFun sells a $2.95 Logic Level Converter that may provide a solution for people that still want to use the Garmin units. https://www.sparkfun.com/products/12009
Thanks!
On Tue, Jan 26, 2016 at 1:44 PM, James Cizek james.m.cizek@gmail.com wrote:
Hi folks,
NO LONGER do this!
Mr. Cizek,
James
KI0KN
Andrew Sylthe
KC9ONA
I really doubt that a level converter will add enough timing skew to
amount to anything. The jitter you see on the internet will greatly
outweigh the skew of a level converter by orders of magnitude...
-Joe
KA3NAM
On Tue, Jan 26, 2016 at 1:44 PM, James Cizek <james.m.cizek@gmail.com> wrote:
Hi folks,
recommended (GPS 18X, 18X lvc, etc...)
NO LONGER do this!
Mr. Cizek,
of.
So this line of GPS's will *NOT* work with an RTCM any longer. Talking to
incoming line, there isn't enough making it to the CPU to trigger a state
change and you will get "PPS Timeout" errors and be unable to achieve GPS
lock.
it's probably a better bet to just get a GPS that has a 5 volt line (Trimble
gear, it's unlikely that that is a good solution.
Just wanted to let folks know so they don't repeat the brain damage I just
James
KI0KN
the bottom of the page. Enter your email address and press the "Unsubscribe
or edit options button"
