Re Chan_IRLP 025.eml (1.68 KB)
I have attempted to duplicate both of your reports. I am running the latest
from SVN (that Steve posted today) and could connect to exp0016 without
any problems and also 9453.
I have no idea???
Date: Sat, 16 May 2009 20:28:16 -0400
To: app_rpt-users@qrvc.com
Subject: [App_rpt-users] [Fwd: Re Chan_IRLP 025]
–Forwarded Message Attachment–
Date: Sat, 16 May 2009 20:23:33 -0400
To: app-rpt@qrvc.com
Subject: Re Chan_IRLP 025
Hi Guys, been testing App_rpt 0.179 Beta and Chan_IRLP 0.25 Beta on node
2249.
So far the audio seems to be fairly stable so far.
A couple of things observed.
1) I can't seem to connect to IRLP reflector 9453. I get connection fail
unless I key up between the IRLP announcement and
The Asterisk announcements. If I key up then I get a successful connection.
Now the weird part, I can connect to IRLP 9454 and 9452 with out having
to key up. It only seems to be 9453 that I have this trouble.
I have tried this on node 2182 as well with the same symptom.
I am told that when IRLP connects to a reflector that a key pulse is
supposed to be sent on one of the 1542X ports and it seems that
it does not get sent or it takes too long to do it unless I key it
manually with my radio.
I don't seem to be having the same problem on other IRLP reflectors.
2) I can connect to EXP reflector 0040 ok but I am having trouble on EXP
0016.
Now EXP node 0016 is set up to feed Newsline. What seems to be happening
is the 0016 node wants to connect using
ADPCM full duplex, my node doesn't like it so it picks GSM as fallback
codec but most of the time I just get "GSM data Error messages on the
screen.
I did see that Steve has a newer versions of App_Rpt_C and ChanIRLP.
But I thought that this might be some good feed back.
Jon VA3RQ
node 2249
Channel 3 of the IRLP Dallas reflector was down for about 24hrs starting mid-day Friday the 16th.
Steve
any problems and also 9453.I have no idea???
Subject: [App_rpt-users] [Fwd: Re Chan_IRLP 025]--Forwarded Message Attachment--
Subject: Re Chan_IRLP 025Hi Guys, been testing App_rpt 0.179 Beta and Chan_IRLP 0.25 Beta on node 2249.
1) I can't seem to connect to IRLP reflector 9453. I get connection fail unless I key up between the IRLP announcement and
Now the weird part, I can connect to IRLP 9454 and 9452 with out having to key up. It only seems to be 9453 that I have this trouble.
I am told that when IRLP connects to a reflector that a key pulse is supposed to be sent on one of the 1542X ports and it seems that
it does not get sent or it takes too long to do it unless I key it manually with my radio.
2) I can connect to EXP reflector 0040 ok but I am having trouble on EXP 0016.
Now EXP node 0016 is set up to feed Newsline. What seems to be happening is the 0016 node wants to connect using
ADPCM full duplex, my node doesn't like it so it picks GSM as fallback codec but most of the time I just get "GSM data Error messages on the screen.
Jon VA3RQ
node 2249------------------------------------------------------------------------
App_rpt-users@qrvc.com
Ok I have now updated to App_Rpt 0181 and Chan_Irlp 026.
So far I have connected to IRLP9453 3 times and it seems ok.
But I'm still having problems with EXP 0016.
After the connect message I get no audio and
here is a snip from the console after I connect to 0016:
[May 17 09:21:54] WARNING[23772]: codec_gsm.c:144 gsmtolin_framein: Invalid GSM data (1)
[May 17 09:21:54] WARNING[23772]: translate.c:211 framein: gsmtolin did not update samples 0
The screen fills up wit these error messages until I disconnect.
Dont know why its trying to do GSM as My normal IRLP node connects with ADPCM full duplex.
Do I not have something set right here? I checked the IAX.conf files to make sure that ulaw, G726aa12 and GSM are enabled.
Jon.
Jon VA3RQ
node 2249
