three Thin Clients than I need to get ready to deploy.
Limey Linux will only work on a
few mini-ITX boards. I was lucky that I
got mine running on a Neoware
CA-22. However, the VIA version did not
work, so I used the i686
version. Booted up just fine.
I have noticed I've had plenty
trouble with the HP thin clients with
other Linux distros for embedded
machines. The older Neowares seem to
run much better, and faster. I’d
like to provide an answer for that, but
I honestly don’t have a clue
why.
DO NOT TRY TO RUN ACID ON A
THUMB DRIVE!!!
Limey linux, when booted, loads
a compresses image to RAM, then
decompresses it. Limey Linux
runs from RAM. ACiD does not. If you try
it, not only will ACiD be slow
to boot on a thumb drive, the thumb drive
will die because of all the
read/write cycles that are meant for a
spinning hard drive. An allstar
user/node owner in Pennsylvania reported
the slow booting.
When dd'ing to flash drive, for
most cases you want to specify bs=16k at
the end of the line. You may
even try “gunzip -c <.img> | of=/dev/sdx
bs=16k”. That is the line I used
on DamnSmallLinux console to burn the
Limey Linux image file to the
neoware’s flash drive. There is zero need
to run cfdisk or any of that
mess before hand.
If I remember right, svcfg is
located in the /usr/bin, or the /usr/sbin
directory. If it is in one of
those two and you cannot do a svcfg from
the prompt, chances are a path
got screwed up somewhere. At the prompt,
you might be able to do
/usr/sbin/svcfg and that should work.
If you want to try running ACiD
on thin client, my best advice is to get
a USB hard drive, and run it
from there. You may have to play around
with the formating on the USB
hard drive for it to work correctly. Some
BIOSs do not like anything other
than VFAT or NTFS for booting purposes.
You may be able to make a double
partition and and have VFAT for
booting, and ext3 for anything
else. Have fun with grub or lilo to make
sure it boots from the correct
partition.
If you really want to get crazy
with it, use of of your Linux servers as
a PXE boot server, and have the
thin client load the Limey Linux from
there. Not sure how well save
would work though…
~Benjamin, KB9LFZ
allstar node 28569
On Thu, 2013-02-21 at 08:51
-0800, Tony KT9AC wrote:
Here are some notes from my
first attempt to get Limey up and running
on a T5710 Thin Client (1.2Ghz
Transmeta Efferon, 512MB flash chip
board (not drive) and 512MB
ram - PM705AA model).
It's not as easy as the Drupal
page would lead one to believe…Limey
is actually ArchLinux and not
CentOS like the ACID install is, so a
lot of expected stuff doesn’t
work. I’m comfortable with Linux and
willing to work through this,
and perhaps a small group could write up
their experiences with this
tier of hardware on the Drupal site.
Notes:
* Downloaded PenDrive
and Ubuntu server ISO to make a bootable
4GB USB drive (this
allowed persistent storage of the cfimg
files under the
/cdrom/doc folder).
* Booted into USB
Rescue and ran fdisk to delete two Windows
partitions off of
512MB flash.
* Ran the “dd
if=cfimg-1.1.5 of=/dev/sdb” and wrote out 128MB
image just fine.
* Rebooted 5710 and it
stuck at “USB Hub detected”. Inserted
above USB drive and
it proceeded to a login prompt. It does
not see the URI at
this point. Tried the 1.1.4 and 1.1.5
version for VIA here.
Tried the i686-1.1.5 version and it
didn’t even get this
far.
* No “This is your
first time…” script ran like the Drupal
page says. No eth0
came up either.
* Found out Limey is
actually “Archlinux” and found the commands
to get on the
internet.
* Ran “ip link set
dev eth0 up” and “ip addr add
<ip/netmask/>
dev eth0”
* Was able to ping my
default gateway and then
edit /etc/resolv.conf
to add “nameserver 8.8.8.8”.
* How does one save
changes back to the flash? The “svcfg”
doesn’t seem to
exist…
* Once on the network,
I switched to /usr/src and ran “getsrc”
which downloaded
Asterisk. I tried to do a “configure” but
that failed. Read the
README and did a usbradio_install but
that also failed.
* This is a really
stripped down version of Linux that uses
128MB of memory after
installed. I am comfortable around Linux
and CentOS and
realize Limey isn’t a beginner’s O/S, one that
I’m willing to work
through.
* I might buy an 8GB
USB drive and use that with a regular ACID
install to get more
functionality as a try of Ubuntu Server
didn’t have enough
disk for an install (it did find all the
devices just fine
under Rescue mode since it’s a newer
distro), or perhaps
CentOS 6.3 and roll my own compile of
Allstar.
Comments/suggestions are
welcome!
Tony
