I tried the dev version of ASL3 for a few weeks. I noticed that quite frequently many of the connected clients to our hub node would simulteneously drop out of the connected list on allmon3 and then reconnect (for those with 'permanent' connections anyway). But not all of them, seems they would switch around in batches.
This would happen at seemingly random times, sometimes many successively minutes apart, sometimes 3 hours apart.
I was not able to correlate this with anything in particular. I did not see any suspiciuous messages in the asterisk cli, or in the asterisk log file.
Our hub node typically hosts 20-29 clients, and runs on a pi3.
I had to revert back to version 3.3.0 since this was too disruptive. So far after going back to 3.3.0 I am not seeing this as of yet with 15 hours of uptime.
Probably not the most helpful report, since I won't be able to test 3.4.3+ on this particular hub at this time. I just want to put this out there if anyone else has seen this on similar client count and hardware.
