Force update to the latest version of hamvoip
I am trying to fix a issue on the hamvoip version of allstar where when i have an allstar node connected to my node then connect an echolink repeater to my node to basically simulcast that repeater’s activity to both my node and the other node for a net but I noticed that when i was monitoring the other node’s dashboard where they use supermon it was receiving my activity for 10 seconds then the time resets to another 10 seconds it’s on a loop and something tells me that it’s on my end and i was apparently dropping out quick so i tried everything that i can on my end like reboot go to ethernet no luck so it came to a solution to update but when i went to ASL-menu and went to update it says in the lines of no updates found and when i tried sudo apt update it says no such command for apt nor other regular linux update commands so i’m looking to see if anyone knows a way to basically force update my hamvoip bypassing that message so that way i can possibly fix the issue that i’m having? I already have a backup stored so that way i won’t loose anything if anything happens during the update
i’m currently on firmware 1.7-06 from november 29 of 2023 and asterisk version 1.4.23-pre.hamvoip-V1.7.1-04 from janurary 22 2022
