for those Limey Linux and or D525MW users who are brave enough
I have compiled a test version of Limey Linux version 1.1.5 that appears
to properly support the new Intel D525MW Atom motherboard.
This is an ‘augmented’ version of the i686-suported-1.1.5 release, so
it should work on all the previously-supported i686 processors, also.
There were some rather major changes (necessary to support SATA
interfaces) in the hard disk driver stuff (even for those MB’s that only
have IDE), so it would be nice if some people could verify that this still
works on non-D525MW motherboards (at least the ones that work in
the normal release).
I have tested this release on both a D525MW and the D945GCLF series
motherboards, and it seems to work just fine.
Also, if you have 5 minutes to wait for it to boot (since the SWINE boot loader does
not support anything faster then USB 1.1 speed, YUCH!), you can flash
the distro onto a USB pen drive (>= 128 MB), and it will work. Once the
OS loads, it runs at full speed, just the initial boot load is PAINFULLY slow.
If you dare, here is the URL for this version:
http://stats.allstarlink.org/limeylinux/downloads/cfimg-D525MW-1.1.5.tar.gz
JIM WB6NIL
Also, this release requires 1GB of RAM (the original 1.1.5 only required 512 MB).
I figured it was time not to be “squosen” into a barely-large-enough memory space.
JIM
To: app_rpt-users@ohnosec.org
Date: Thu, 6 Oct 2011 06:46:45 -0700
Subject: [App_rpt-users] for those Limey Linux and or D525MW users who are brave enough
JIM WB6NIL
Hi Jim!
I have been testing chan_simpleusb on the HP T5710 platform - running ACID with a whopping 256MB of RAM. I was going to try the Limey Linux install to see how this would handle on these thin clients. However, based on your note below... I am wondering whether Limey is even worth pursuing....
ACID and chan_simpleusb seems to work great... I am almost done with week 2 of my block test!
The only snag (and it may just be cosmetic) is that I see the INIT 2.86 (or whatever) reloading on the screen - but that doesn't see to affect the performance of the system.
Cheers!
Ramesh.
512 MB).
I figured it was time not to be "squosen" into a barely-large-enough
memory space.
JIM
are brave enough
This is an 'augmented' version of the i686-suported-1.1.5 release, so
it *should* work on all the previously-supported i686 processors, also.
interfaces) in the hard disk driver stuff (even for those MB's that only
loader does
slow.
JIM WB6NIL
_______________________________________________ App_rpt-users mailing
list App_rpt-users@ohnosec.org
ohnosec.org
ohnosec.org
Hi Jim, does this new Limey distro support chan_usbradio full dsp,
full duplex and can it support multi nodes?
Jon VA3RQ
App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
Thin clients?? What do you think we are, and eating disorder clinic or something ?? :slight_smile: :slight_smile:
First of all, Limey only supports VERY specific motherboard, of which that is not one.
Also, since it runs entirely out of RAM, you need more then that for it to work in a reasonable
manner.
JIM
Date: Thu, 6 Oct 2011 09:55:25 -0400
Subject: Re: [App_rpt-users] for those Limey Linux and or D525MW users who are brave enough
Hi Jim!
based on your note below… I am wondering whether Limey is even worth
pursuing…
ACID and chan_simpleusb seems to work great… I am almost done with
(or whatever) reloading on the screen - but that doesn’t see to affect
Cheers!
Ramesh.
512 MB).
memory space.
JIM
are brave enough
loader does
slow.
JIM WB6NIL
ohnosec.org
ohnosec.org
ohnosec.org
Yes, the same way all of the distros have for a while now. All the distros “support” chan_usbradio with full dsp,
however the VIA motherboards and some of the older i686 ones dont have enough
CPU power.
Certainly all the ATOM-based boards and even some earlier ones will do at least 2 channels
and even the newer dual-core ATOMs should do more.
JIM
Date: Thu, 6 Oct 2011 10:19:51 -0400
Jon VA3RQ
appears
release, so
processors, also.
that only
this still
series
flash
work. Once the
PAINFULLY slow.
    JIM WB6NIL
<-- OK Jim; So I will save myself from those Limey's!
Thin is good ... thin makes my hydro meter spin slowly. These things run of 13.8V @ ~ 600mA. Me likes that :).
Cheers!
Ramesh.
p.s., for all those than inquired last week - the ISO and install scripts for my FREE STAR* project are now on my site:
http://www.va3uv.com/iso.htm
The install script will even allow you to install on top of an ACID build - how's that for playing nice!
that is not one.
manner.
Why dont you try a Beagleboard and LOX board… It runs at 1/4 of that power!
JIM
Date: Thu, 6 Oct 2011 11:54:11 -0400
that is not one.
manner.
← OK Jim; So I will save myself from those Limey’s!
Thin is good … thin makes my hydro meter spin slowly. These things
Cheers!
Ramesh.
ISO-Images
build - how’s that for playing nice!
ohnosec.org
<-- Pretty simple Jim - 'cos I don't have one! - the HP's cost us $28US a pop - the mod to install a 4GB Microdrive costs around $16 or so. So for a total investment of $44 US, we're good to go. I think these HP's are awesome (but beauty is in the eye of the beholder! - LOL :slight_smile:
R.
On 06/10/2011 11:55 AM, Jim Duuuude wrote:
Why dont you try a Beagleboard and LOX board.. It runs at 1/4 of that power!
