first time run
Hi! I used the how to on the wiki to install a radio less node on a Linode server (64bit) ASL 1.01
All went well Asterisk is running got real good add libc_x86 to run dahdi_test and the result were pretty good.
Now I would like to have the server to download its programing from the portal
just could not find how to do it.
Anyone can point it to me?
If it could be added to the wiki I am sure it would help many others
1st, I have not used the tool to do that as I have created my own
files but,
I think there is a menu item in the system set-up
run asl-menu as sudo or root
or
  there is a file somewhere in /usr/local/sbin that does that
trick.
Perhaps someone else will chime in with the exacts…
…mike/kb8jnm
On 6/19/2018 12:18 PM, Pierre Martel
many others
From the ASL portal, (menu bar) select then select the “server” you wish to download to.
This initiates a configuration update process to the server remotely.
You may also use the /usr/local/sbin/node-setup script or use the tools in /usr/local/sbin/asl-menu
Nathan Hardman
nhardman1428@gmail.com
N8THN@ARRL.NET
I knew the way to start the download from the portal. Just that since the node had never connected to ASL there would be no way to send the config from the portal.
the asl-menu ( with the patch) did the trick thanks
Nathan Hardman
N8THN@ARRL.NET
Strangely, even after the node is reporting to ASL network properly and being online. If I try to send the server download command from the portal it fail with that on asterisk CLI:
[Jun 19 14:00:53] NOTICE[1973]: chan_iax2.c:9471 socket_process: Rejected connect attempt from 67.215.233.178, request ‘0@allstar-sys’ does not exist
Nathan Hardman
N8THN@ARRL.NET
