Is there any reason why the power amp cannot be placed between the duplexor and antenna? My repeater will be 2 modular 1 watt radio modules, a 20W capable 6 cavity duplexor and a Mirage power amp.If the amp is after the duplexor then cool, if not then a more expensive duplexor will be required…
TIA
Steven Donegan
KK6IVC General Class FCC License
Silver State Car #86 www.sscc.us
Yes. The duplexor is like a tx/rx switch.
If the PA is between the duplexor and the antenna, then you won’t be able to
receive because the signal from the antenna won’t pass through the PA in
reverse.
Is
Even if you could, how you would get a rx sig back through the amp ?
While it was working ?
It's the reason for the duplexer.
Think about it for a few....
FULL DUPLEX
We all have those moments....
...mike/kb8jnm
required...
TIA
 Steven Donegan
www.sscc.us_______________________________________________
App_rpt-users@ohnosec.org http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
To unsubscribe from this list please visit http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down
to the bottom of the page. Enter your email address and press the
It’s the reason for the duplexer.
Think about it for a few…
FULL DUPLEX
We all have those moments…
…mike/kb8jnm
required…
TIA
 Steven Donegan
“Unsubscribe or edit options button”
You “could” use 2 antennas as long as you had enough vertical separation and not use a duplexer at all. If you’re at a site with other transmitters you’ll want a good filter/duplexer.
FULL DUPLEX
…mike/kb8jnm
required…
TIA
 Steven Donegan
Sounds like it’s really a “Notchplexer”…OK for home use but thats about it. Since you have very low power your going to lose most of it in the filtering. Run 2 antennas and a single can on the RX…
FULL DUPLEX
…mike/kb8jnm
required…
TIA
 Steven Donegan
FULL DUPLEX
…mike/kb8jnm
required…
TIA
 Steven Donegan
