Find nodes that are talking
I like the feature on stats.allstarlink.org which shows the time since last unkey, but I wish there was a way to sort it, it would be really nice if I could find all of the nodes that are currently talking so I could connect in if I want to find someone to talk to or do a demonstration etc.
First, has anyone done such a thing, where you grab the last unkey from the stats.allstarlink and show all of the nodes that have had traffic sorted by last unkey?
Second, if I wanted to do it, what programming language would I have to learn to script it for my ham radio website and how hard would it be?
Skyler KDØWHB
Hi Skyler,
Is this list that what you like?
I have write it in few minutes with php.
http://82.135.26.20/lastactivity.php
73 de Florian DL1FLO
Hi,
I hope it works, here is the sourcecode:
Interesting demo that worked well. thanks.
the src code seems to have got smashed up in the list server email relay does any one have this code working that can send to me directly as an attachment zip or other
Im not a php expert tried to fix it but its too badly broken for me to fix.
thanks. Barry
At 12:16 09/08/2015, Florian Schmid wrote:
Hi,
Barry,
Attached is a working lastactivity script. This is meant to be run on a local http server.
On the RPi2 put it in /srv/http
Then browse your_RPi2_ip/lastactivity.php
You need to have php setup in your http server as per Allmon instructions. This is already done in the RPi2 image.
For other distributions you would have to set things up in httpd.conf and place the file in the http path before it will work.
73 Doug
WA3DSP
lastactivity.tgz (909 Bytes)
Date: Sun, 9 Aug 2015 14:59:14 +0100
To: [email protected]
Subject: Re: [App_rpt-users] Find nodes that are talking
Hi,
thanks. Barry
[email protected]
Thanks for the src code I did fix all this as I have the same as you sent to me.
but neither work
[Sun Aug 09 17:07:11 2015] [error] [client 81.149.82.229] File does not exist: /var/www/html/nodes/style.css, referer: http://www.gb3gr.co.uk/nodes/lastactivity.php
[Sun Aug 09 17:07:11 2015] [error] [client 81.149.82.229] PHP Notice: Undefined offset: 6 in /var/www/html/nodes/lastactivity.php on line 24
[Sun Aug 09 17:07:11 2015] [error] [client 81.149.82.229] PHP Notice: Undefined offset: 1 in /var/www/html/nodes/lastactivity.php on line 96
[Sun Aug 09 17:07:11 2015] [error] [client 81.149.82.229] PHP Notice: Undefined offset: 2 in /var/www/html/nodes/lastactivity.php on line 96
[Sun Aug 09 17:07:11 2015] [error] [client 81.149.82.229] PHP Notice: Undefined offset: 3 in /var/www/html/nodes/lastactivity.php on line 96
[Sun Aug 09 17:07:11 2015] [error] [client 81.149.82.229] PHP Notice: Undefined offset: 4 in /var/www/html/nodes/lastactivity.php on line 96
[Sun Aug 09 17:07:11 2015] [error] [client 81.149.82.229] PHP Notice: Undefined offset: 5 in /var/www/html/nodes/lastactivity.php on line 96
I can see that it gets the stats file then starts to parse the data looking for 0 in Last Key/Unkey bits of the data and
then sorting in order of number size
the parsing is not actually working..?
lsnodes on this ox and allmon all work its a std linux install from acid all working fine
Barry
At 16:50 09/08/2015, you wrote:
Barry,
I don’t believe it works as it should. it’s reporting my node as not keyed up in 6 days
and that’s not true. seems to me it’s reporting how long the systems has been up and
not how busy they are.
73 Russ WL7LP
Alaska Morning Net - Net Manager
IRLP node 7369,
AllStar 29332, 29265,
To: Doug Crompton [email protected]; “[email protected]” [email protected]
Sent: Sunday, August 9, 2015 8:17 AM
Barry,
local http server.
to me.
but neither work
the parsing is not actually working…?
all working fine
Barry
[email protected]
What is the error? What system are you using? Acid? RPi2? etc.
Are you setup for Allmon (changes to httpd.conf) ?
Check the http error log. /var/log/httpd/error_log and access_log
73 Doug
WA3DSP
Date: Sun, 9 Aug 2015 17:17:26 +0100
To: [email protected]; [email protected]
Subject: RE: [App_rpt-users] Find nodes that are talking
Barry,
local http server.
to me.
but neither work
all working fine
Barry
Yes that works fine I will now do a diff to see what the problems is.
many thanks to the originator author it is a handy tool for testing
Barry G8SAU
At 17:54 09/08/2015, you wrote:
Barry,
I had the same results with Dougs version. At Least it didn't sort on the last key/unkey for me.
Using the php code that Florian sent it does work here ... however I am just trying it from the terminal and it is not being served anywhere.
Thanks, that is exactly what I was looking for!
Barry,
I had the same results with Dougs version. At Least it didn’t sort on the last key/unkey for me.
Using the php code that Florian sent it does work here … however I am just trying it from the terminal and it is not being served anywhere.
Barry G8SAU
[email protected]
Skyler Fennell
amsatnet.info
KDØWHB
[email protected]
It reports only RF activity at the node listed. My hub has lots of activity but it does not show up unless coming directly from that node. THIs somewhat makes sense because if it showed all the nodes keyed that were connected to all hubs the list would go crazy!
73 Doug
WA3DSP
Date: Sun, 9 Aug 2015 16:45:03 +0000
73 Russ WL7LP
IRLP node 7369,
Barry,
local http server.
to me.
but neither work
all working fine
Barry
[email protected]
[email protected]
