Several questions
I took an new home AllStarLink node, tied it to a transciver to feed a mountaintop repeater. I ended up with a “shotgun” effect; i.e., the home transceiver node would drop, the repeatertail would bring the home node back up and repeat endlessly until it was disabled. Is it possible to setup such a configuration? What has to be modified
I noticed that the “hang time” on the home node is 8-10 seconds, where do I reduce that to something like two seconds?
I used Run SimpleUSB – Tune Menu option. One web page I found showed that menu had 22 selection; the one that comes up only has 11 selections. Is the one with 22 selections no longer a valid reference?
I hear a morse code ID with the node’s callsign, but its low in deviation. How do I change that to make it a bit louder?
jd
