Fan control?
Hi guys,
I’m running a pair of UHF CDM1550’s in full duplex with one of the new Repeater Builder Rim “lite” RM interfaces:
http://www.repeater-builder.com/products/usb-rim-lite.html
It does not look like I can tap the GPIO’s very easily on these boards, nor can I tell if GPIO 5-8 is available for general use looking at the schematic:
http://www.repeater-builder.com/products/pdfs/RB_RIM_Max.pdf
What I’d like to do is drive a relay board to switch a fan on if the receiver is active or there is traffic coming in to the node, being connected to another station or hub for example. I read over the GPIO and event management subsystem documentation, and it looks like that’s what I need, but I don’t have a parallel port nor can I tap the GPIO’s on my interface easily (or even know if they can be used as per the above).
Looking for ideas here if anyone else has encountered this, would prefer the logic/relay board approach vs. say a temperature controlled switch on the heatsink or something.
Stephen
K1LNX
they weren’t designed as full interfaces with all the signals that a DMK or their own RB URI brought out, hence the price (and thinking board form factor) and feature set. Looks like they were designed to interface between a radio by direct plug in on the header on the back of the CDM and a computer running app-rpt and not much else.
I’m thinking anything extraneous to that mission was left out, since there are multiple options (DMK,RB, DIY) that already accomplish the same thing.
Kyle K0KN in Olathe KS wrote a set of scripts that do fan control based on the event subsystem setting a flag after x seconds on transmit, setting a GPIO pin, running them for y seconds after the repeater goes idle. DMK published a simple schematic for a relay circuit that buffers the GPIO; 1 resistor, 1 diode, 1 transistor, and a pcb relay. Been using his scripts and that circuit since '11, with zero issues to control the fans on my machines here.
Bryan
On Jun 21, 2016, at 07:24, Stephen - K1LNX k1lnx@k1lnx.net wrote:
Hi guys,
Stephen
K1LNX
nod … correct, I knew that when I bought it, but didn’t think this all the way through (as usual!!!). I do have a URI and URIx but really liked the repeater maker interface so I picked one (along with others) up at Dayton this year to give them a try.
Thanks for that! I went and looked at Kyle’s scripts and that looks like exactly what I need, so I may need to get creative to make this thing work, unknown at this time if I’ll be able to pull it off or not.
Stephen
K1LNX
Bryan
Hi guys,
Stephen
K1LNX
Or you could just install a time delay relay board.
http://www.ebay.com/itm/12V-Delay-Relay-Module-delay-time-adjustable-ICSE026A-/401139250016?hash=item5d65c33360:g:5tsAAOSwM4xXZAzu
73,
Eric Guth
4Z1UG
Allstar: 28422
QSO Today
On Behalf Of Stephen - K1LNX
to give them a try.
Stephen
K1LNX
Bryan
Hi guys,
Stephen
K1LNX
Stephen,
As others have commented, to help keep the price down and the footprint small, the GPIO of the CM119 were not brought out to pads on the RIM_Lite family of products.
The exception to this is on the Maxtrac version where I/O 5-8 were brought out to buffer/inversion transistors that are meant to be used for channel steering on those radios. These pins can be re-mapped and used for other purposes if channel steering is not being utilized.
Scott
Scott Zimmerman
Amateur Radio Call N3XCC
474 Barnett Road
Boswell, PA 15531
On 6/21/2016 7:24 AM, Stephen - K1LNX wrote:
Hi guys,
    I'm running a pair of UHF CDM1550's in full duplex with one of the new Repeater Builder Rim
"lite" RM interfaces:
Repeater Builder USB-RIM Lite
It does not look like I can tap the GPIO's very easily on these boards, nor can I tell if GPIO 5-8
What I'd like to do is drive a relay board to switch a fan on if the receiver is active or there is
the GPIO and event management subsystem documentation, and it looks like that's what I need, but I
don't have a parallel port nor can I tap the GPIO's on my interface easily (or even know if they can
Stephen
K1LNX
