Failed login at token request on SharkRf M1ke device for 4 days
As I emailed a few days ago, my W6BBH call sign and password that is working to get me logged into the Allstarlink page, is being kicked back as bad when I am trying to get Token Request verification using the SharkRf M1KE device. Echolink, Dstar and Brandmeister don't have those issues and the M1KE works fine otherwise. Attached are the screenshots with fault msgs.
Just now I saw the posting that the Web Transceiver auth program is phasing out. Is this my problem? How else can i tell the SharkRfLink to connect to Allstar to avoid this problem?
  Bill Hotalen, W6BBH
Confirm you can login to www.allstarlink.org with your callsign and password. if that works, please reach out to SharkRF for support. AppAuth has nothing to do with your problem.
