My AllStarLink node is tucked away in a pelican case with my radio and router in the back of my car so I’d like to add a switch on the outside that can safe-shutdown the Pi before I pull the power cord.
Is using the power button on the RasperryPi 5 a good way to shut down the node, specifically Asterisk? Or should I use one of the GPIO pins with a specific shutdown script?
an orderly shutdown is generally a more desirable method than just yanking the DC power
the raspi5 has a button which is polled by the firmware which signals the watchdog timer (WDT)
just letting the firmware do its thing won't get you a fully orderly shutdown, though, i think. it is possible to intercept the shutdown signal, run script(s) or sudo systemctl poweroff, and then let the firmware do the rest, as best i can ascertain
