Let me see if I have this sorted out. If
we ditch the RC-210’s we can vote. We can add simple URI’s to bring
in a WX receiver, IRLP, possibly a RF link? Also, when I referred to remote
base I was referring to a control link. We don’t want people listening to
the input J I just want simple.
[mailto:[email protected]]
Sent: Saturday, April 12, 2014
7:51 AM
To: Wayne
Cc: app_rpt mailing list
Subject: Re: [App_rpt-users]
External Controller Plus Allstar
I forgot to address your remote base requirement. RTCMs do not support
remote bases. You will need a computer and URI where the remote base is. But
check to see if you radio is supported. Allstar doesn’t support many.
Tim
:wq
On Apr 12, 2014, at 7:37 AM, Tim Sawyer [email protected] wrote:
So the way a voter a voter works is it samples the noise (like squelch
does) on each receiver and then takes the signal with the least noise and sends
it to the transmitter. If you have a controller in front of the RTCM the
controller will always be sending the receiver to the transmitter even if the
signal has noise.
RTCMs are just smart IO devices. Think of them as not being much
different than a sound FOB on the end of an ethernet cable. Generally, with
RTCMs, the computer will be at some central location on the ground and the
RTCMs will be far away on a high hill or tower.
In your case, because your IP network is only between your two hills,
the computer will be at one site or the other. So wherever the computer is
located, is where you would connect in your IRLP box with a URI or other sound
FOB. Echolink could be on that same (or a different) box. Echolink is a app
that runs on the Allstar computer no sound FOB or URI required.
It really comes down to this: you either use Allstar or you
don’t. The other issue you’ve not touched on yet it touch tone
commands. Trying to work out a scheme where the RC-210 commands and the Allstar
commands don’t conflict is difficult and confusing for your users.
My recommendation is to save the RC-210s for another project. Put
RTCM’s on your three hills connected directly to the repeaters. Put the
Allstar computer on the ground on your IP network. Get 5 Allstar nodes: Use one
node for the voting system of Site 1 and 2. Use another node for site 3. Use a
node for the IRLP URI. Use a node for Echolink. That way you have the most
flexibility while using the lease amount of hardware and having a clean TT
command structure.
Tim
:wq
On Apr 12, 2014, at 4:53 AM, Wayne [email protected] wrote:
One more thought, if I may. How do voted
systems bring in IRLP or EchoLink? Aren’t we talking about something
similar? I’m really bummed now.
Sent: Friday, April 11, 2014 9:57 PM
To: Wayne
Subject: Re: [App_rpt-users] External
Well, I don’t know how much help I can be here. I
don’t use voting, don’t like it, never will, but that’s me. Trying to
combine a voted system of RTCM’s into a regular RF link may be
interesting. Not sure how the RTCM will react to a “link” input
as it is used to discriminator input as far as know.
There are people more familiar with RTCM’s voting and
simulcasting than I am that may be able to help you.
I use URI’s and have just connected them directly to
controller ports, like you would a link radio, and they work and sound
great! I have even used them as the controller and sound even better!
Sorry I can’t be much more help than that!
good luck and 73 de Greg
----- Original Message -----
To: ‘app_rpt
mailing list’
Sent: Friday, April 11, 2014 8:05 PM
Hi Greg,
Thank you for taking the time to reply.
Our operational goal is a hybrid system
that is voted and simulcast between two repeaters 100 miles apart but
overlapping input coverage. They have no LOS. Site 1 and 2 are on a VLAN
provided by the site vendor but Site 3 only has wireless internet. We will be
using a RF link. We don’t want to use the public internet.
Each location will also have a remote base
and a WX receiver with a FIPS code for that area only. Using some switching
logic we will disconnect from Allstar if the WX receiver triggers. No need to
send marine weather alerts to the desert.
The topology expected is Site 1 → Site
2 (Allstar; voted), Site 1 → Site 3 (RF link; different frequency). Since
it isn’t our VLAN we can’t use Ubiquity or similar to link to Site
3 as an unvoted device. There is also significant overlap of outputs but I sure
would love to be voted and have only one pair. That would be so nice. We
already have RC-210’s so we don’t want to toss them aside and buy
RTCM’s as just controllers as has been suggested. We will end up with
RTCM’s for the voting ($$$) and the RC-210’s for control. Using the
RC-210’s allows us cell phone access to the RC-210’s as well as
through the remote bases.
As you probably know the RC-210’s
have a 4th port that
is no frills. The WX receivers can go on this “port”.
Sent: Friday, April 11, 2014 12:48 PM
To: Wayne
Wayne,
I think what we need is to figure out what exactly you are trying to do.
If you are running a full simulcast/voted system,
(multiple transmitters, multiple receivers with ALL receivers and transmitters
connected via Allstar) and want a backup RF link, you will need 3 total
ports. 1 for the repeater, 1 for the backup RF link and 1 for
the RTCM. Just treat the RTCM like a “Link Radio” as that is
basically what it is.
Since you are new to allstar, I assume that is not
the case.
If you are just trying to connect your repeater or repeater
system to Allstar, a RTCM is serious overkill! I would recommend a DMK
URI for 1/4 the price. You can even use it as the controller and
eliminate your current unit! It will still run as a standalone repeater
when offline.
Does that help?
Let us know what you have and what you would like to do and
we could probably be more help.
73 de Greg KJ6KO
To: ‘app_rpt
mailing list’
Sent: Friday, April 11, 2014 9:48 AM
“…If you
mean you want to parallel app_rpt/allstar with a existing hardwired controller,
you will need to use “DUPLEX=0 & LINKTOLINK=YES” on the primary
node for that/each location. It will give you the same fullduplex but
with no hang time etc that you can parallel with existing controller. A port on
your rc-210 if i remember them correct…”
I sincerely appreciate the answer but as I
mentioned I am new to Allstar. As such I don’t know how to ask the
question. I received this reply and appreciate the time it took to write. But I
wonder if another user can offer insight into wiring. Do I wire the Allstar
device to Port 1 and then the repeater to port 2? Do I keep the option of voted
simulcast? Doing so only leaves one port remaining. Am I missing something in
the translation here? Thank you. I appreciate your time.
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 9666 (20140411) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
[email protected]
To unsubscribe from this list please visit http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the
page. Enter your email address and press the “Unsubscribe or edit options
button”
confirmation. If you have trouble unsubscribing, please send a message to the
list detailing the problem.
http://www.eset.com
database 9667 (20140411) __________
http://www.eset.com
database 9668 (20140411) __________
http://www.eset.com
[email protected]
button”
http://www.eset.com
http://www.eset.com
[email protected]
button”
[email protected]
ohnosec.org and scroll down to
the bottom of the page. Enter your email address and press the
“Unsubscribe or edit options button”
