Excessive channel.c:1117 __ast_queue_frame: Exceptionally long voice queue length error messages
Since the last update, I am getting nonstop WARNING messages in the CLI -
[2026-04-26 20:18:10.592] WARNING[2434096][C-0000051f]: channel.c:1117 __ast_queue_frame: Exceptionally long voice queue length (97 voice / 99 total) queuing to Announcer/IAXLink-00006e90;1
Not sure exactly what this is telling me. Any suggestions?
Eric
K2CB
Might be related this spurious bug we see sometimes:
Does it go away if you restart Asterisk?
Or do you have a link perpetually trying to connect but failing?
Yes, it goes away for a little while after a restart. Then starts up again.
I did have one node in the allmon3.ini that is temporarily OOS. I just REM'ed it out in the ini file, and restarted again. I'll check it again in a little while.
Eric
K2CB
Looks like the fix was REM'ing out the OOS node in allmon3.ini.
Thanks for the guidance.
Eric
K2CB
This is a bug that we need to figure out. Trying to connect to a dead should not result in a long voice queue. Is this an external "connect" method? (Not a rpt.conf startup macro?)
