Thought I’d share this thread with the list since it might be helpful to someone trying to setup a local sip phone for reverse autopatch.
Bob and I went off the list when we first got started on this because I was afraid the thread could get quite lengthy if we ran into the (almost) inevitable problems. However, everything worked the first time through a combination of luck on my part explaining things (blue moon) and Bob’s excellent ability to read, interpret, and follow my drivel.
Bob, if there were things I explained incorrectly below that you figured your way around, please chime in so that the next unwary ham who tries this will be forewarned. Also note that some of this is specific to Bob’s SIP phone but in looking through the manual for the phone, I found it to be pretty typical of other SIP phones I’ve worked with. Finally, apologies for the reverse ordering of the thread versus the way we normally (try) to order thread (newest reply at bottom).
73’s
Keith
KF7DRV
Allstar Node 2541
---------- Forwarded message ----------
Date: Sun, Jan 31, 2010 at 12:03 PM
Subject: SIP IP pHONE config - was: Connect notifications via AGI or System scripts
To: Keith Williamson hkwilliamson@gmail.com
hi keith
got the first part done
sip show peers
Name/username Host Dyn Nat ACL Port Status
9009/9009 10.0.0.40 D 5060 Unmonitored
1 sip peers [Monitored: 0 online, 0 offline Unmonitored: 1 online, 0 offline]
whats next?
Thanks in Advance
Bob Brown, WØNQX
Kansas City Metro Area
Quis custodiet ipsos custodes?
On Sun, Jan 31, 2010 at 12:09, Keith Williamson hkwilliamson@gmail.com wrote:
OK great. Next step is to get the phone registered with the Allstar node. I’m going to assume the phone is connected to the internal network the node is on and for the purposes of this explanation I’ll say the internal IP of your Allstar node is 192.168.0.1 (and that that IP is either static or gets a static lease via DHCP). Obviously, substitute your node’s actual internal IP.
In the web interface for the phone, enter the Allstar node internal IP in ALL of the following fields of Line 1 settings for Profile 1:
SIP Proxy Server
Outbound Proxy Server
Registrar Server
Outbound Registrar Server
Leave the SIP Proxy Server Port and Registrar Proxy Server Port set at the default of 5060.
Also in the same Line 1 Profile 1 menu, you need to set the phone’s extension info. You can make this whatever you want but for the purposes of this explanation we’ll call it Bobs208. Set Bobs208 in the following fields:
Phone Number
User Name
Authorized ID
Finally, you need to set a password for authentication. We’ll use “secret123”. Set the following field to secret123:
Authorized Password
This should be enough on the phone side of things so now down at the bottom of the menu, do Save Settings followed by Logout.
Now we move over to the Allstar node. Open /etc/asterisk/sip.conf with your favorite editor (I’m a vi guy myself) and add a stanza for your phone (below the end of the [general] stanza) that would be something like this:
[Bobs208]
type=friend
secret=secret123
context=radio-control
host=dynamic
disallow=all
allow=ulaw
transfer=no
Now save the changes to sip.conf and exit the editor. Next go into the CLI (e.g. asterisk -vr) and type “sip reload” to force asterisk to reread the sip.conf file. At this point, asterisk should be ready register your phone.
Probably the most dependable way to get the phone to activate the changes you made to the phone’s SIP parameters and to force the phone to attempt to register with Allstar/Asterisk is to just power-cycle the phone.
I haven’t read enough about this phone to know how the phone indicates it’s registration state after it finishes booting but you can watch the Allstar CLI and you should be able to see the registration occuring. You can also type the following CLI command to check if you phone is registered:
sip show peers
Let me know how all this goes and then we can proceed to the final step once the phone is registered.
73’s
Keith
KF7DRV
On Sat, Jan 30, 2010 at 11:57 PM, Bob Brown - WØNQX bbrown@byrg.net wrote:
ya mine is a virgin fone and the default is 1234
i got this from a ip phone vendor/wholsaler it was a freebie he says it was sip compatable
i have managed to log into it from the web interface and from the admin menu in the front panle.
Thanks in AdvanceBob Brown, WØNQX
On Sat, Jan 30, 2010 at 22:45, Keith Williamson hkwilliamson@gmail.com wrote:
Hi Bob,
I found the manual for your T207/T208 phone…hopefully you have that too. Getting the phone registered with Asterisk requires that the phone be an “S” model (T207S or T208S) which means it has SIP firmware. The T207M and T208M models run MGCP which isn’t compatible with Asterisk. The other requirement is that you need to know the admin password. If it’s never been changed it should be the default “1234”. You can configure the phone settings either directly on the phone or via your web browser (although you need to at least configure the TCP/IP parameters using the phone menus before you can switch to using the more convenient web interface).
Perhaps you have already done this part and have the phone connected via Ethernet to the network the node is on?
Let me know and we can go from there.
73s,
Keith
On Sat, Jan 30, 2010 at 10:02 AM, Bob Brown - WØNQX bbrown@byrg.net wrote:
my ipphone: TSIPP2008BG-R1
sure any help would be great!
On Fri, Jan 29, 2010 at 23:01, Keith Williamson hkwilliamson@gmail.com wrote:
Hi Bob,
No problem. What make/model of ipphone is it? The first thing required
is a stanza in sip.conf defining the extension, user, password, etcfor that particular phone. The required elements vary from phone to
phone so let me know what kind you have. After creating the entry in
sip.conf, you just do a “sip reload” at the CLI and check to see ifthe phone gets registered OK. Once you have that, you just need to add
a stanza to extensions.conf to enable the reverse autopatch.There’s a pretty complete description of what’s required in the ACID
Admin Manual.
Cheers,
Keith
On 1/29/10, Bob Brown - WØNQX bbrown@byrg.net wrote:
hi keith
i would be interrested in your config files to set up the ipphone
on your node
i have a 4 line ip desk phone i would like to set up to do what you describe
i am not very fluent in asterisk set up for ip fones.
would you be willing to share?
On Fri, Jan 29, 2010 at 22:04, Keith Williamson > > > > > > hkwilliamson@gmail.comwrote:
Hi,
Recently, I got reverse autopatch configured on my simplex node (2541) and
everything works great. In the shack, I have a Polycom IP501 speaker phone
that I use to monitor or connect into QSO’s on the node. Out of the shack,
I
can call into the node using my Blackberry and do the same. So the nextchallenge is to get quick notifications of users connecting into the node
either via radio or Internet (Echolink and Allstar…no IRLP yet). I
created
a pair of Twitter accounts; one for the node and another for mepersonally.
I added my node’s Twitter account to the ones I follow with my personal
account and created an AGI scripts that formats a curl command which posts
some of the context variables passed in when Asterisk invokes the script(context name, extension, callerid, etc). I then added the AGI call into
various extension stanzas in extensions.conf to test. If, for instance, I
do
a reverse autopatch and connect to the reverse autopatch “extension”, Ialmost immediately get an SMS tweet on the Blackberry. Great. However, it
seems that connections via the radio are not processed in any way in
extensions.conf (thought [default] stanza would apply but apparently onlyapplies to autopatch), and inbound connections from either Allstar or
Echolink, while processed through [radio-secure], hang on the AGI call and
don’t proceed to the following call to rpt. I’m assuming this is becauseAGI
calls generally follow an “Answer” and are only valid in the connected
state. I tried “deadAGI” since it doesn’t seems to be dependent on being
inthe answered state but it hung the same way. It’s possible I’ve got a
problem in the AGI script which is causing the hang but it certainly
doesn’t
occur when the AGI call follows “Answer”.So I’m looking for help to understand other possible ways to invoke a
script that calls curl to post the tweet when a radio user makes an
outbound
connection to Allstar or Echolink and when an Echolink or Allstar userconnects in to the radio.
Ideas?
Thanks and 73’s
Keith
KF7DRV
App_rpt-users@qrvc.com
Sent from my mobile device
