One of my 3 nodes on the same box will not register. The subject error message (obtained with: statpost_program=/bin/wget,-q,--timeout=15,--tries=1,--output-document=/root/stats.txt) has the wrong/old IP address. Also note /var/lib/rpt_extnodes has the following for my 3 nodes...
FYI, I moved nodes 2530 and 2535 to a new box leaving the 2528 behind for a while which in the one that is now screwed up. I'm pretty sure I have everything set up right on the new box as nodes 2530 and 2535 register ok and 2528 is set up the same way.
nodes...
statpost as nothing to do with IP address refresh. Statpost is for
status updates only. IP addresses are updated with register statements
in iax.conf. Please take a look at the the register statement(s) in
iax.conf. There should be one register statement for each active node on
the box.
