I have download app for iPad. I entered may account details for both Allstar and Echolink.
It works but some nodes reject connection with "Rejected: No authority found "error msg.
Most nodes connect without a problem but some like HUBNET reject connection.
What has to be done to sort this issue out?
Brian
I might suggest contacting the app author or their support group.
Thanks for the reply
Did you check in manager.conf and change the setting from local 127.0.0.1 to 0.0.0.0? This allows apps such as repeater phone to log in to your node.
;bindaddr = 127.0.0.1. ;local interface only
bindaddr = 0.0.0.0.
Thanks for that info, however I have contacted one of the Hubnet administrators who has told me that Hubnet does not support phone apps other than EchoLink
Brian
Also have managed a work around to this problem.
I have linked to a GB3RT which has multiple links including Hubnet and no problem connectiing.
So have access to Hubnet via an alternate path of nodes
