Error Message When Attempting to Connect to my hub
I copied an error message I am getting on the CLI of my Hub Node when I attempt to connect from my Repeater Node. I have been unable to connect to any other nodes for a while. I am not sure what changed but suddenly I could not connect to anyone any more.
I copied and pasted the error message below in hopes that someone could point me in the right direction in finding the problem. I am guessing it has something to do with my router or modem.
I currently use a ASUS RT-AC68U router which is provided IP from a Comcast supplied modem/router that is bridged so that its only a modem. I also have a cisco switch that I plug all my hardware into.
Any help would be greatly appreciated.
Connected to Asterisk currently running on K0PWO_Hub (pid = 2372)
Verbosity is at least 3
– Accepting UNAUTHENTICATED call from 192.168.20.1:
requested format = gsm,
requested prefs = (gsm|g726aal2|ulaw),
actual format = g726aal2,
host prefs = (g726aal2|gsm),
priority = mine
– Executing [41488@radio-secure:1] Rpt(“IAX2/192.168.20.1:4569-1947”, “4148 8”) in new stack
[Dec 27 16:33:51] WARNING[2930]: app_rpt.c:22704 rpt_exec: Node 40968 IP 73.169. 7.203 does not match link IP 192.168.20.1!!
== Spawn extension (radio-secure, 41488, 1) exited non-zero on ‘IAX2/192.168.2 0.1:4569-1947’
– Hungup ‘IAX2/192.168.20.1:4569-1947’
David Dean, K0PWO
Arapahoe County Colorado
(720) 350-2053 cell
(720) 207-9030 fax
Dude,
put:
40968 = radio@192.168.20.1/40968,NONE
in the [nodes] section of rpt.conf.
Obviously, you have 2 app_rpt servers on the same LAN (behind the same NAT).
This, and a line in the OTHER server’s rpt.conf (that will allow connections the other way),
is necessary in this type of configuration.
Jim
To: app_rpt-users@ohnosec.org
Date: Sat, 27 Dec 2014 18:09:13 -0700
Subject: [App_rpt-users] Error Message When Attempting to Connect to my hub
priority = mine
David Dean, K0PWO
(720) 350-2053 cell
(720) 207-9030 fax
Ok I understand that and will make those changes but I am still unable to connect to other nodes outside of my lan. Any thoughts on that.
Sent from my iPhone
On Dec 27, 2014, at 6:41 PM, Jim Duuuude telesistant@hotmail.com wrote:
Dude,
put:
Jim
priority = mine
David Dean, K0PWO
(720) 350-2053 cell
(720) 207-9030 fax
This morning I followed the advice given by several members on the list. I added in the nodes section of both system
40968 = radio@192.168.20.1/40963,NONE on the hub box
41488 = radio@192.168.20.1/41488,NONE on the repeater box
And I still get connection failed error messages
Some back ground on what I have
· Comcast internet
· The Comcast supplied modem/router is bridged for modem gateway only
· ASUS RT-AC68U Router which feeds a Cisco Switch which both boxes are currently plugged into
· Node 41488 is my hub node and has port forwarding for port 4572 which it is assigned and configured
· NODE 40968 is my repeater node and port forwarding for port 4569 which it is assigned and configured
· Both machines for the moment have ssh of 222 (default) set
· 41488 (my hub) is using static ip (on my LAN) of 192.168.20.235
· 40968 (my repeater) is using static ip (on my LAN) of 192.168.20.243
The repeater was working fine up until about a month ago when It quit connecting to any nodes.
This morning I reset my router and reconfigured anything – no change
This morning I reformatted my repeater box and reconfigured using the Allstar Portal – no change
When I attempt to connect my repeater to my hub, which is on the same LAN with the node settings added that are listed above I get this error message on the CLI
[Dec 28 08:37:53] WARNING[2500]: chan_iax2.c:4328 handle_call_token: Address 192 .168.20.243 failed CallToken hash inspection
[Dec 28 08:37:55] WARNING[2508]: chan_iax2.c:4328 handle_call_token: Address 192 .168.20.243 failed CallToken hash inspection
[Dec 28 08:38:05] WARNING[2500]: chan_iax2.c:4328 handle_call_token: Address 192 .168.20.243 failed CallToken hash inspection
K0PWO_Hub*CLI> [Dec 28 08:37:53] WARNING[2500]: chan_iax2.c:4328 handle_call_tok en: Address 192.168.20.243 failed CallToken hash inspection
K0PWO_Hub*CLI> [Dec 28 08:37:55] WARNING[2508]: chan_iax2.c:4328 handle_call_tok en: Address 192.168.20.243 failed CallToken hash inspection
No such command ‘[Dec 28 08:37:53] WARNING[2500]: chan_iax2.c:4328 handle_call_t oken: Address 192.168.20.243 failed CallToken hash inspection’ (type ‘help [Dec 28’ for other possible commands)
No such command ‘[Dec 28 08:37:55] WARNING[2508]: chan_iax2.c:4328 handle_call_t oken: Address 192.168.20.243 failed CallToken hash inspection’ (type ‘help [Dec 28’ for other possible commands)
K0PWO_Hub*CLI> [Dec 28 08:38:05] WARNING[2500]: chan_iax2.c:4328 handle_call_tok en: Address 192.168.20.243 failed CallToken hash inspection[Dec 28 08:37:53] WAR NING[2500]: chan_iax2.c:4328 handle_call_token: Address 192.168.20.243 failed Ca llToken hash inspection
No such command ‘[Dec 28 08:38:05] WARNING[2500]: chan_iax2.c:4328 handle_call_t oken: Address 192.168.20.243 failed CallToken hash inspection[Dec 28 08:37:53] W ARNING[2500]: chan_iax2.c:4328 handle_call_token: Address 192.168.20.243 failed CallToken hash inspection’ (type ‘help [Dec 28’ for other possible commands)
K0PWO_Hub*CLI> [Dec 28 08:38:05] WARNING[2500]: chan_iax2.c:4328 handle_call_tok en: Address 192.168.20.243 failed CallToken hash inspectionexit
No such command ‘[Dec 28 08:38:05] WARNING[2500]: chan_iax2.c:4328 handle_call_t oken: Address 192.168.20.243 failed CallToken hash inspectionexit’ (type ‘help [ Dec 28’ for other possible commands)
Once again, anybody have any ideas on what is wrong?
Thank you for any help provided.
David
