Error after running astupdate
Hi Jim / Steve;
I've ust ran the astupdate script on node 2424 and get the following error when trying to start asterisk:
pbx_config.so => (Text Extension Configuration)
[Sep 24 19:51:10] ERROR[15375]: app_rpt.c:19965 load_module: Zaptel version 1.4.12.1 must at least level RPT_A to operate
I also still have the /root/acid directory so I am wondering whether the update did not complete....
Any ideas?
Thx,
Ramesh.
Ramesh Dhami (VA3UV) wrote:
Hi Jim / Steve;
Any ideas?
Thx,
Ramesh.
App_rpt-users@qrvc.com
Congratulations! You just stumbled upon the check we put in app_rpt to
ensure that the latest Zaptel drivers are loaded and used.
Zaptel drivers are kernel modules loaded in your kernel are not from the
update, but are from the prior software load. Just restarting Asterisk
will not reload the kernel drivers. You must reboot the system as well
to ensure the latest Zaptel drivers get loaded into the system.
This is one of the driving reasons we requested everyone do a complete
install for this release and avoid the use of astupd.
<-- Hi Steve; Thanks! - I forgot about the re-boot; I have since re-booted and the system seems to be online again... now for the stress test...
Cheers,
Ramesh.
