Equivalent connection as a static IP address
I run an AllStarLink node on a Linode Debian Linux virtual computer that acts like a hub where stations can each connect, the equivalent of a Internet IP repeater station. The Linode Debian virtual computer has a public static IP address.
I would like to be able to run the AllStarLink hub from my home location, but I don't have a static IP address from my home location. I only have a DHCP public IP address. I tried to setup an AllStarLink hub at my home location, and there are connection problems from stations when my DHCP IP address changes. To get a static IP address at my home, I would have to change my internet service to much more expensive business internet service. Is there a way that I can run an AllStarLink hub from my home location that's equivalent to having a public IP address, so that the incomming AllStarLink connections can connect to my AllStarLink hub when my public DHCP IP address changes?
Use 44net. That will get you a public static IP address.
On Oct 28, 2026, at 13:26, David Borchard [email protected] wrote:
Someone replied to a topic you are Watching.
| KY0L
October 28 |
You do not need a static IP address. But, you do need a consistent public IP address (not a CGNAT'd IP).
When your node registers with the AllStarLink network we capture the current IP address of your server. That IP address is made available to other nodes so that they can connect to your node.
For a home network, the registered IP would be the DHCP address provided by your ISP. If that DHCP address ever changes then the next time your node updates its registration the new IP would be captured.
What is your "WAN IP" of your home router? Does it start with 10, 172.16-31, 192.168, or 100? If so, then you're on CGN. Provide the output of asl-node-auth-check. That will flag if you're behind a CGN that will cause you problems. If you just have a DHCP IPv4 address that's publicly routable, the worst-case time to propagate a change across the AllStarLink system would be 480 seconds. And your public IPv4 address shouldn't change unless you restart your router or change out the hardware in most cases.
I work in network engineering for an ISP that uses CGNAT, and I approve these messages.
I'll tell you how I did it, with a caveat: I have a service from Spectrum and the outside of my router has a public IP. That's the key for this method. If you are in a CGNAT situation, the other answers here about 44.net and so on are for you. With that in mind, what you do is configure port forwarding on the router, and possibly a "hairpin" rule. This basically translates anything arriving on the router's public address that is going to the IAX port of 4569 to the node's inside IP (private) address.
So If your outside IP is 1.2.3.4, and your inside node is on 192.168.1.1, a packet coming to you on 1.2.3.4:4569 is translated to 192.168.1.1:4569, and sent on to your node. Note that the port on your node can be different if needed, so if you already have a node on 4569 you can translate 4569 to 4568, or 4570, or however you want based on your node configuration. But the default or most
The "hairpin" lets you seamlessly connect to the 1.2.3.4 address from the inside of your router using another system. So if you grab a phone with DVSwitch and it's on your wifi, it will connect to your node from inside, as the router will "hairpin" or turn around, the outbound traffic from the phone and send it right back in to the node.
Note this: if you reboot the router, it's possible the outside IP on the router will change. In that event, the node will have to re-register with the ASL directory which by default happens every 3 minutes. If needed, you can manually re-register by running:
asterisk -rx "iax2 reload"
or more radically:
sudo systemctl restart asterisk
but this will disconnect any connections that may be up.
If you want to go farther, you can establish a public name for your node, and use dynamic DNS to register it, but that's another topic....
Hope this helps.
Steve N5TIN
Thanks for all the suggestions. I have a DHCP public IP address that periodically changes. When the public IP changes, I think it will take awhile for the AllStarLink system to recognize my new public IP address.
I started researching the 44.Net solution. I already registered my login and verified my license with the FCC PDF file. Now, I’m trying to learn how to setup the 44.Net Connect and firewall on a computer running Debian 13.7.
I’d appreciate being pointed towards videos or documentation that would help me install the 44.Net Connect, and installing and configuring the firewall for an AllStarLink ASL3 hub node.
Dave KY0L
44Net Connect page in the Manual:
Is there a configuration process required to re-establish the connection to the AllStarLink network when the public IP address changes. Or, does the AllStarLink network automatically recognize the new public IP address without having to do any configuration changes. If configuration changes are required to re-establish the AllStarLink connection, what configuration change is necessary?
As long as you haven't hard-coded an IP Address in the "Proxy IP" field of the server your node(s) is attached to, your next registration call after the IP changes is noticed and propagated. It may take 6-7 minutes depending on the node-lookup method. Files are only updated every 5 minutes. DNS is within 60-75 seconds.
