Hello,
Could I trouble a moderator to please enable Web Transciever (WT) access on my AllStarLink account?
My callsign is VK2BAT
Thank you very much.
Laurence
There is nothing to activate. All accounts are able to use WebTransceiver mode. The node you're connecting to has to permit it however.
That setting is per node, not per account and is enabled by default, unless you explicitly disable it on a node. You have no node numbers on your account yet, just FYI.
Thank you very much for your kind response. It since gave confidence to pay and install Repeater Phone App and everything AllStar works a treat. However; locating WT within the website still eludes me. Spent many hours on tutorials before reaching out.
For example one of my many local club nodes 554210 shows capability. No problems connecting via Repeater Phone App. However there is nothing within my account to select for WT when I select that node or one of the many other nodes that cites open permission . Hence; I thought it requires a request to enable.
It’s a setting in each node’s settings, under:
Portal→Node Settings→(Node #)
(it’s a Y/N pulldown that says something like “Allow Web Tranceiver/Repeaterphone/DVSwitch Access)
You can enable/disable each node individually.
Since you have no node numbers yet, you wouldn’t see it.
