Doesn’t get much easier than this… straight from the samples config file with the information changed as required.
[el0]
confmode=no
call=W7QO-R ; Change this!
pwd= ; Change this!
name=Test ; Change this to your real name!
qth=Atlanta,GA ; Change this to your actual QTH!
email=adamson_alan@hotmail.com ; Change this!
maxstns=20
rtcptimeout=10
node=710254 ; Change this!
recfile=/tmp/recorded.gsm
astnode=28578 ; Change this to your active Allstar node number!
context=radio-secure
server1=server1.echolink.org
server2=server2.echolink.org
server3=server3.echolink.org
With that setup I get these errors which have been discussed before… and it doesn’t matter if I change the server names to naeast.echolink.org, etc.
[May 23 14:19:52] ERROR[2033] chan_echolink.c: Error in parsing header on server1.echolink.org
[May 23 14:20:22] ERROR[2031] chan_echolink.c: connect() failed to connect to the Echolink server server2.echolink.org
[May 23 14:20:22] ERROR[2033] chan_echolink.c: connect() failed to connect to the Echolink server server2.echolink.org
[May 23 14:20:43] ERROR[2033] chan_echolink.c: Unable to connect to directory server server2.echolink.org
[May 23 14:20:43] ERROR[2033] chan_echolink.c: Error in parsing header on server3.echolink.org
[May 23 14:21:03] ERROR[2033] chan_echolink.c: Error in parsing header on server1.echolink.org
I’ll go look to see if there have been changes to the chan_echolink.c file that I’m not running but I just built everything with the distribution makefile yesterday. This was talked about on this forum last year, but I never found a resolution other than it worked for some and not for others…???
Alan
Sent: Wednesday, May 23, 2012 1:23 PM
To: adamson_alan@hotmail.com
Subject: Re: [App_rpt-users] EchoLink
It is not unusual for one of the echolink servers to be down; as long as you can talk to one of them, it should work.
I think that, after you come on line, it may be some time before you can actually USE the echolink feature, while you wait for their system to updpate.
Incorrect header information is another story - if you post your configuration (minus the password) maybe someone will see a problem - or not - in which case there was some compile issue …
Ken
-----Original Message-----
To: App_rpt-users App_rpt-users@ohnosec.org
Sent: Wed, May 23, 2012 8:34 am
Subject: [App_rpt-users] EchoLink
So, learning to run before I can walk :)… With my newfound enthusiasm and a debian install. I wanted to test out functionality figured an easy way was to see about getting EchoLink working as well.
So I added the echolink.conf file, made the changes for my specific EchoLink node and restarted. However I get all these errors about not being able to connect to their servers, header information not being correct, etc.
I did some scanning and found that others have experiences the same thing. Anyone have this working on a recent install?
Second, is there some type of echo conference bridge or reflector (Sorry for the use of the term, but it’s appropriate)… I need some way to test audio without being live on the air, etc?
Alan
`_______________________________________________`
`App_rpt-users mailing list`
`App_rpt-users@ohnosec.org`
`[http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)`
