Jim,
I believe what people are asking for is to have app_rpt send status updates when connects and disconnects occur. Below is the format for echolink status reporting taken from Skip’s WB6YMH source for thelinkbox. Looks like the connect message would be “=NNTECHTALK at 1530” for example. I assume the disconnect message would be " On @ 1545".
EchoLink sends a packet once every 10 minutes to aprs.echolink.org. It also
sends a packet when the node status changes (i.e., when somebody connects or
disconnects, or the node comes online or goes offline).
The packet is an RTP control packet, and thus is sent to port 5199.
The CNAME portion is the node callsign (including -L/-R), followed by a
slash, followed by a “password”, which is actually a hash of the callsign.
However, at this time, the password field is ignored by the server; a future
release of the server will verify the authenticity of the packet by its
source IP address. So the callsign can be repeated in this second field.
The format of the LOC portion is as follows:
)EL-nnnnnn!DDMM.HHNXDDDMM.HHW0PHGphgd/FFFFFF/PPPyyyyyyyyyyzzzzzzzz
Where:
nnnnnn is the 6 character node Name or Callsign (right-padded
with spaces to 6 chars)
DDMM.HHN DDDMM.HHW is the LAT/LONG of the node, using degrees, minutes,
and 100ths of minutes, and E/W/N/S
X is the letter “E”, for EchoLink
0 is a “zero”,the ICON character
p is the power (encoded)
h is the antenna height (encoded)
g is the antenna gain (encoded)
d is the antenna directivity (encoded)
FFFFFF is the frequency in KHz
/PPP is the PL in whole number Hz
yyyyyyyyyy Second line on a D7 (11th to 20th on a D700)
zzzzzzzz last 8 not shown on a D7 but are on the D700
Formats for the variable field YYYYYYYYYY and ZZZZZZZZ:
Offline: " Off @HHMM........" can contain some comment
On-Line: " On @ HHMM........" Time it returned to ON-Line
Busy: " Busy HHMM........" Time it went busy
Connected: "=NNnnnnnnn at HHMM" Shows call/Name of connection
The encoding of the p/h/g/d fields is as follows:
DIGITS 0 1 2 3 4 5 6 7 8 9
POWER 0, 1, 4, 9, 16, 25, 36, 49, 64, 81 watts SQR(P)
HEIGHT 10,20,40, 80,160,320,640,1280,2560,5120 feet LOG2(H/10)
GAIN 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 dB
DIR omni,45,90,135,180,225,270, 315, 360, . deg (D/45)
For example: // )EL-K1RFD !4118.52NE07329.97W0PHG7430/144300/000 On @0444
Rdgfld
Tim
:wq
On Jan 20, 2011, at 8:08 AM, Tim Sawyer wrote:
I suspect that the app_rpt echolink client is not reporting to the mothership, not that the mothership is ignoring us. If that’s the case, maybe our exalted developer would add echolink status reporting.
Tim
:wq
On Jan 20, 2011, at 7:16 AM, Bryan D. Boyle wrote:
We’re not running Echolink software…so, while we’re able to register our nodes, I’m thinking that the Echolink mother ship is studiously ignoring, for the sake of display, alternative software that speaks their language.
ohnosec.org
