I used the audio adjust howto to set my levels and the repeater sounds reasonable. But Echolink RX audio is very low and Echolink users say my TX audio is high. I'm using chan_echolink. Is there a way to adjust the Echolink levels?
Sorry for the post.... I just found this on the web site:
erxgain=-3.0 ; defaults to -3.0 db
etxgain=3.0 ; defaults to 3.0 db
Tim
:wq
I'm changing these values but they don't seem to change the audio levels. I put these two lines in my rpt.conf under the node stanza and restart Asterisk. Any ideas what I might be doing wrong.
Tim
:wq
Tim
:wq
Tim
:wq
Tim
:wq
If you are using ACID, then your problem is most likely a downrev
version of app_rpt.c Echolink gain adjustments require app_rpt.c version
0.179 or later. The stock version of ACID has contains version 0.174.
You can manually update app_rpt be using the procedure updated here:
