one of the ASL/Echolink nodes I manage is not showing online on Echolink today seems like a recent development.
I rebooted the node a few times trying to see if it would resolve but no go.
Here’s a screenshot of the asterisk logs. do i need to change servers or is echolink having an issue?
Outside of logging in via wifi in the same NAT/ext-IP on a phone, you probably hit the cause as the second largest reason for it.
It happens from time to time. I keep them all listed and comment them out when there is a issue.
It will start with the first on the list and move through it until it gets a reply up to 3. Then back to top of list.
So, you do need to allow a little time as it tries each as well. Not sure how long.
