Then I had problems with the Dahdi driver with the block of asterisk and I solved
Now I find myself working everything but I have a problem for echolink and I have this error
I doubt the issue is related your config, but it is possible.
Many little things to know about this.
If this is a inbound connect, and I have to guess it is from the playback, there are several reasons why it might not process.
If you are using a relay that has an issue.
OR
You are attempting to connect via the same network the node is on (WAN) for echolink will only allow one connect per ip address and if you are connecting via wifi it will do something similar.
In this case, I would suggest you turn wifi off on your phone for the test.
And if it is some other device, know it can’t be done on the same network.
Have a friend connect preferable who has a cable/broadband connection that does not have to relay.
Some of the relay servers are not config’d well.
But don’t adjust you config till you check / test for above.
Hello to you and thanks for the answers then I made the connection to one of our colleague try and the result is that it has connected to my -r the thing is that the server that hosts Allstar has just been passed in Ampnet and therefore the Echolink clientk of the smartphone is to be used with the proxy
Sorry, I am not reading your post well. But I don’t want to leave you hanging if you still need help.
So,
Understanding your colleague was able to connect to -r asl attached node.
If you still have an issue, just state what that is, we will start from there.
