How can you play an audio greeting to connecting echolink nodes on allstarlink?
The easiest way is to write a shell script to play the files desired.
Then in rpt.conf, use the following command…
connpgm /path to script/file.sh
This will run the file on connection to the node.(associated asl node to the echolink node)
However, I myself have never tried this with a echolink connection.
So, report back and tell us if it works for you.Or the problems/failure.
Thanks for the quick reply Mike…but honestly, I have no idea…
