2 issues, perhaps related, new install
- From the asl-menu, CLI node tune echo is not working, won't even key the radio. It does transmit and rx from other comands.
- Immediately upon starting Allmon3 web page it shows my node in the "Transmit - Local Source" status with the timer starting at the moment of accessing.
Equipment: RPi4b, CM108 modified with PTT transistor, etc., connected via mic/earphone cable to a TYT MD-380uv.
Thank you in advance,
Eric AJ4QR
