I am trying to make a dtmf to work by dtmf my supermon dashboard by using the dtmf coding and its not working as anyone got a copy so im can edit? This is the code im got
I think what you want to do is set these up as ... not macros but assigned commands
09 = cmd, /opt/Analog_Bridge/dvswitch.sh tune 91 ; North America
*09 would execute this if that command (09) is not in conflict with anything else, like a zero.only command somewhere.
But not macro. You can not assign/contruct a command inside a macro, you do use already constructed commands in a macro.
You could then use a *09 'command' inside of a macro.
I not sure im understand do any one have full rpt file and im can edit that file and but my own talk groups in or can you put a command line in here and i copy it in to my rpt file please ?
