Hello, when I connect to a node through DVSwitch (Android software) it connects through ASL-WT like it is supposed to, but when it connects is gives the node I connected to but says connected to node then my call sign not my node number. Does my node number only show or say it over the connection time when it is a radio to radio connection? Sorta new to the ASL stuff.
I believe when using WT, the node is the login user, hence the callsign.
For it is not a node but a WT user and has no node number.
But for best answers, you should post that to groups.io /dvswitch user forum.
Ok sweet thank you. I got it over to the group.
