DVSwitch and ASL3
Good day,
I understand security is tighter on the system, so the question I have is I have these scripts that I got elsewhere, not mine, that would change the DMR Networks, like from BM to TGIF. They work perfectly in Root, so I presume it has to do with the security.
part of the instructions are:
these files in the /opt/Analog_Bridge
BM_chng.sh Changes MMDVM Bridge to Brandmeister
TGIF_chng.sh Changes MMDVM Bridge to TGIF
BM_chng.sh
#! /bin/bash
cp /opt/MMDVM_Bridge/MMDVM_Bridge_BM.ini /opt/MMDVM_Bridge/MMDVM_Bridge.ini
systemctl restart mmdvm_bridge.service
TGIF_chng.sh
#! /bin/bash
cp /opt/MMDVM_Bridge/MMDVM_Bridge_TGIF.ini /opt/MMDVM_Bridge/MMDVM_Bridge.ini
Make the scripts Executable:
chmod 755 /opt/Analog_Bridge/BM_chng.sh
chmod 755 /opt/Analog_Bridge/TGIF_chng.sh
but when I try to use a DTMF command, they don’t work.
13 = /opt/Analog_Bridge/TGIF_chng.sh
14 = /opt/Analog_Bridge/BM_chng.sh
I do assume it is something new due to all the security updates with ASL3, but I am a newbie at this, so I am asking for assistance on getting this to work.
thank you & 73
Rob - K6IRK
Indeed, on ASL3 the asterisk process is running as the “asterisk” user instead of root, so if you are trying to have asterisk execute scripts it can only execute them as the “asterisk” user.
To give permission for asterisk to copy the ini files in, you can try
sudo chown :asterisk /opt/MMDVM_Bridge/
sudo chmod 775 /opt/MMDVM_Bridge/
To fix the systemctl restart command, you could create polkit rules, like the ones that were just added to ASL3 HERE.
For instance, create a file /etc/polkit-1/rules.d/50-mmdvm.rules
And put these contents in the file
polkit.addRule(function(action, subject) {
    if ( action.id == "org.freedesktop.systemd1.manage-units" &&
			subject.user == "asterisk" && (
   		     	action.lookup("unit") == "mmdvm_bridge.service")
 		{ return polkit.Result.YES; }
The above edit probably requires a logout/login, or a restart to take effect.
Now, to test executing the scripts as the asterisk user use the following command
sudo -u asterisk /opt/Analog_Bridge/TGIF_chng.sh
If this works, then the DTMF macros should work as well. If it is not working, then you will need to continue to make edits to the commands in the scripts or to the permissions on the system until it does work.
Disclaimer: I did not test any of these changes as I am not running a MMDVM Bridge. I’m just sharing general Linux knowledge that should get you closer to where you want to be.
Polkit rules take effect immediately.
k6irk - Do you have or can direct me to the full instructions for setting this up?
I would like to give it a try. :slight_smile:
Sorry, I don’t even have that setup, It appears I was trying it a year ago, but never continued to persuit it.
I don’t even know where I had found the initial information on it.
So sorry, if I run across it, I will post it.
Rob
Ok - Thank you for letting me know!
I am trying to find a way that I can tigger a script in ASL3 that connects to and opens a TG via DTMF.
Just haven’t found it yet.
