I have been noticing an interesting problem. Audio drops on my repeater and link sporadically for maybe 500ms now and then as a conversation is taking place. If I watch debugging data from CLI it usually coincides with DTMF being sensed in certain voices. Is there a way to increase the time it takes for the system to recognize DTMF? Or is there something else going on.
My experience always has been that the standard install is WAY too sensitive
to DTMF false decodes.
There may be an easier way to do this (I hope to find), but, one way is to
remove the RADIO_RELAX compiler flag
in
/usr/src/astsrc/asterisk/menuselect.makeopts
it should read only:
MENUSELECT_CFLAGS=LOADABLE_MODULES
Then cd astsrc
And
./configure
Make
Make install
There is a menu for changing compiler flags in recent releases - you have to
make the menuselect program when you do the install (I think)
Ken
-----Original Message-----
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-
bounces@ohnosec.org] On Behalf Of Chris(KB2FAF)
Sent: Sunday, December 18, 2011 2:06 PM
To: App_rpt-users@ohnosec.org
Subject: [App_rpt-users] DTMF voice falsing
Hi,
Thanks for any pointers...
Chris
KB2FAF
in
Then cd astsrc
And
./configure
Make
Make install
Ken
Hi,
Chris
KB2FAF
in
Then cd astsrc
And
./configure
Make
Make install
Ken
Hi,
Chris
KB2FAF
In my case, the DTMF commands work fine with this setting.
The only time I have trouble is when there is some multipath distortion ...
driving to the next traffic light is usually enough to fix that
Ken
Sent: Sunday, December 18, 2011 11:02 PM
To: Chris (KB2FAF)
Cc: Ken; App_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] DTMF voice falsing
But can you still reliably function the system?
Tim
:wq
On Dec 18, 2011, at 7:12 PM, Chris(KB2FAF) wrote:
> Ken,
> Your suggestion made a huge difference!
> Thank you.
> Chris - KB2FAF
>> sensitive to DTMF false decodes.
>> is to remove the RADIO_RELAX compiler flag in
>> Then cd astsrc
>> And
>> ./configure
>> Make
>> Make install
>> have to make the menuselect program when you do the install (I
think)
>> 73
>> Ken
>>> Hi,
it
>>> Chris
>>> KB2FAF
>>> _______________________________________________
>>> App_rpt-users mailing list
>>> ohnosec.org
> ohnosec.org
I tried removing RADIO_RELAX but touch tone decoding was way too slow for my taste. Jim mentioned that the parameters could be adjusted to perhaps find a happy medium between radio_relax and phone mode. The parameters are in /usr/src/astsrc/asterisk/main/dsp.c under the RADIO_RELAX compiler directive. Not being a C programmer and knowing even less about the DSP routines, I couldn't make much sense of the values. But maybe others could check it out and explain the parameters to the rest of us.
Tim
:wq
Ken
To: Chris (KB2FAF)
Tim
:wq
Ken,
Thank you.
Chris - KB2FAF
Then cd astsrc
And
./configure
Make
Make install
think)
Ken
Hi,
it
Chris
KB2FAF
I only use it for manual commands. I can reliably punch the rubber buttons
on my microphone at about 2 digits per second. It has no trouble keeping up
with that.
If your setup has a speed dialer and you are dialing 10 digit phone numbers
and passwords or whatever, I can see there might be an issue... not the
majority of cases, I imagine. Anyway, having to wait 5 seconds for a phone
number to go through every once in a while would be acceptable to me as a
trade off for continuous unwanted muting of words every minute or so ..
Ken
To: Chris (KB2FAF)
Tim
:wq
taste.
This is an interesting problem. I never hear this on any of my nodes.
Could it be that there is too much audio driving the URI? Not sure, but does
the URI RX level drive the DTMF detection? If so, you might be too hot..
Might be worth trying to adjust that down as a test to see what happens?
[mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Tim Sawyer
Sent: Sunday, December 18, 2011 11:25 PM
To: Ken
Cc: App_rpt-users@ohnosec.org
Tim
:wq
Ken
To: Chris (KB2FAF)
Tim
:wq
Ken,
Thank you.
Chris - KB2FAF
Then cd astsrc
And
./configure
Make
Make install
think)
Ken
Hi,
it
Chris
KB2FAF
No I don't think so.
The URI is adjusted per the instructions and the receiver gain settings are
reasonable (rxmixerset=375)
My guess is that it is the users' vocal characteristics and to some extent
the rig he/she is using.
If you have one or two of these individuals on your system, it will drive
you crazy unless you change the RADIO_RELAX setting.
Ken
Sent: Tuesday, December 20, 2011 9:59 AM
To: 'Tim Sawyer'; 'Ken'
Subject: RE: [App_rpt-users] DTMF voice falsing
does the URI RX level drive the DTMF detection? If so, you might be too
hot..
happens?
To: Ken
to the rest of us.
Tim
:wq
> distortion
> Ken
>> From: Tim Sawyer [mailto:tim.sawyer@me.com]
>> To: Chris (KB2FAF)
>> Tim
>> :wq
>>> Ken,
>>> Thank you.
>>> Chris - KB2FAF
>>>> way is to remove the RADIO_RELAX compiler flag in
>>>> Then cd astsrc
>>>> And
>>>> ./configure
>>>> Make
>>>> Make install
>>>> you have to make the menuselect program when you do the install (I
>> think)
>>>> 73
>>>> Ken
>>>>> Hi,
>> it
>>>>> Chris
>>>>> KB2FAF
>>>>> ohnosec.org
>>> ohnosec.org
Some people will false DTMF like crazy and others won't touch it. I have one guy who sounds like he's talking the PL of with every ahh and ohh. He's not falseing the PL by the way, I see his DTMF on the asterisk console.
Tim
:wq
To: Ken
Tim
:wq
Ken
To: Chris (KB2FAF)
Tim
:wq
Ken,
Thank you.
Chris - KB2FAF
Then cd astsrc
And
./configure
Make
Make install
think)
Ken
Hi,
it
Chris
KB2FAF
I used to see DTMF falsing on almost every transmission ... maybe 50 milliseconds or so when watching from the CLI at radio debug level 1. After the change, I see nothing, even when I lean on the mic and intentionally over deviate. I'm not noticing any delayed decoding of DTMF either.
Thanks!
N5ZUA
----- Original Message ----- From: "Ken" <ke2n@cs.com>
in
Then cd astsrc
And
./configure
Make
Make install
Ken
Hi,
On 1/23/12 9:15 AM, "Steve Agee" <n5zua@earthlink.net> wrote:
I just tried this and it works GREAT!
After
Thanks!
N5ZUA
sensitive
to
in
Then cd astsrc
And
./configure
Make
Make install
have
to
Ken
Hi,
Chris
KB2FAF
