I am actually wanting things just a little
different. Until I can get internet to each site so I can
get asterisk there I would like to use a command that I
could enter and anything following it would generate the
DTMF.
Here is my current scenario… I use one of my UHF
machines as the hub (for now) and I have different machines
that listen to the hub. At times other repeaters will
connect in as well. DTMF muting is enabled on the local
repeater but DTMF is NOT muted on the link side that goes to
the hub. This way I can control the repeaters through the
links if I need to until I can get some type of ip network
setup.
Say a cop command is created for this and I make
932 my dtmf for that cop command and I was to issue 1234 to
turn on something at a remote site, I would like to enter
*9321234 and have the controller either pass or regenerate
the 1234.
I hope this makes sense. I know a couple of
groups that would like to do this as well and that is the
only reason they haven’t moved over to app_rpt. They have
seen how powerful it is! One of the systems has 15
repeaters in it and the only way they would be able to do
something would be a piece at a time. That is why this
would be so handy!!!
Corey N3FE
app_rpt-users-bounces@ohnosec.org
[mailto:app_rpt-users-bounces@ohnosec.org] ** On Behalf
Of** VE3GIH Gordon Hewit
Sent: Monday, January 24, 2011 12:34 PM
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] DTMF passthru
KE2N Ken
suggested using the propagate_dtmf command in the rpt.conf
file, as a way to propagate DTMF signals to other nodes.
I need this capacity to allow our members access to the
local phone patch. However with all nodes set to duplex=2
(full duplex) and propagate_dtmf=yes, I’m still not
getting DTMF on the other local repeaters. The asterisk
console sees the DTMF, but Asterisk isn’t passing the
digits onwards.
Does
anyone have a suggestion about what else I can try?
VE3GIH
Gord
Date: Sat,
22 Jan 2011 09:42:49 -0500 (EST)
To: n3fe@repeater.net, telesistant@hotmail.com,
Subject: Re: [App_rpt-users] DTMF Allow
Cory
I think there is a setting for this
propagate_dtmf= see [** MailScanner warning: numerical
links are often malicious:**
http://209.159.155.200/drupal/node/134](http://209.159.155.200/drupal/node/134)
<snipped>
GL
Ken
KE2N
Gordon Hewit
289-800-1473 (home)
This message was scanned and is believed to be clean.
Click
here to report this message as spam.
