New to Allstar. I just set up a node on a ESXI host running a debian 9 VM. I’m using a modified CM108AH. I finally was able to get the CM108 talking to the VM and have ran through the simpleusb tune and all seems fine except; I can’t connect to any nodes using dtmf. When in the asterisk CLI, the DTMF commands sent via the radio all show up correctly however nothing happens. I have tried running the rpt fun commands in the asterisk cli and the system seems to accept them but nothing happens.
I have reviewed all of the config files and searched the forum but can’t seem to come up with anything.
What could I be missing? I suspect it’s something I have overlooked but I can’t seem to find it.
Any help / suggestions would be greatly appreciated!
Check if your node is registered with iax2 show registry Asterisk CLI. Also check if you are receiving the latest nodes list with tail /var/lib/asterisk/rpt_extnodes.
Here is the output from tail /var/lib/asterisk/rpt_extnodes
repeater@merlin:~$ sudo tail /var/lib/asterisk/rpt_extnodes
[sudo] password for repeater:
542591=radio@107.191.45.44:4568/542591,107.191.45.44
542740=radio@167.179.95.73:4569/542740,167.179.95.73
542741=radio@45.32.249.17:4569/542741,45.32.249.17
;Generated 5593 records in 0.136 seconds.
;Served in 0.012 seconds.
;Served from cache: Yes
;Generated at 2021-03-29 23:19:31 UTC by f0537a4b8c66
I have attempted several nodes. 50795 was the last. I’m using asterisk cli- rpt fun 54124 *350795 but nothing happens. I’ve tried rpt fun 54124 *80 and nothing… I ssh’d into node 50795 and sent the same command to 54124 and received a message that the connection failed.
I can seem to find any more reference to how it asl works and how all of the config files interact. It seems to me that there is a lot of documentation missing regarding how things work? Maybe just me…
I googled “cancel_pfxtone” and see results on HamVoIP, DVSwitch and here on Community. I did not read much of it as the noise level is too high for my pea brain. Try that yourself and see if you can make any sense of it. I can’t.
Yes, I did, could get much out of it. I not sure what to think about it. In fact I joined the DVswitch group too. I wish I could find more info in what in happening in the background. I’ll keep looking. This is an ASL version. Not sure how HamVoIP plays into it. Again, I’m just new to this…
