DTMF codes to activate function
Hi,
Just as a heads up to anyone new reading this and learning about app_rpt and also as a question to the more experienced node owners out there, I have noticed a little niggle with the DTMF tone sequences used to activate functions on app_rpt.
Here’s the scenario:
In my rpt.conf I have a function:
94 = cop,something or other
All is fine until I try and add a command 941 to do something else.
The new code wont work and app_rpt seems to ignore the extra digit on the end and just activates the function that is associated with the code 94.
I’m not sure if this is really a bug or not but it certainly had me teased for a good few hours recently when I was adding some new functions to my node.
I was expecting code 941 to work but it just wasnt - I was testing a new feature which had been added and I wasnt sure if I had busted the feature or something else had gone wrong!
I changed the code to 95 and all worked as expected!
Just something to be aware of really I guess unless its an easy fix for the app?
Cheers,
Matt
G4RKY
Node 2250
I found that doing this helps:
941 = cop,something
942 = cop,something else
943 = cop,foo
94 = cop,do something now
Jim K6JWN
On Tue, May 26, 2009 at 2:21 PM, Matt Beasant g4rky@yahoo.co.uk wrote:
Hi,
Cheers,
Matt
G4RKY
Node 2250
App_rpt-users@qrvc.com
Jim Nessen K6JWN
Email: nessenj@jimsoffice.org | Ph: 530.979.0894
IRLP: Nodes 3598 and 3633 | Echolink: 83598 K6JWN-R | AllStar: Nodes 2142 and 2165
Ah, thanks Jim, yes I can see how that would make sense if the app parses the file from top to bottom and stops at the first valid code it gets to.
Obvious really I guess! Doh!
Cheers, Matt
2009/5/26 James Nessen nessenj@jimsoffice.org
941 = cop,something
943 = cop,foo
Jim K6JWN
Hi,
Cheers,
Matt
G4RKY
Node 2250
Jim Nessen K6JWN
Its not a bug. Its not a shortcomming. Its a well-defined lookup table, concisely stated. If you specify a 2 digit function, thats it. no more functions with 3 or more digits
starting with the same 2 digits as the 2 digit function.
Jim WB6NIL
Date: Tue, 26 May 2009 15:05:53 -0700
To: g4rky@yahoo.co.uk
CC: app_rpt-users@qrvc.com
Subject: Re: [App_rpt-users] DTMF codes to activate function
941 = cop,something
943 = cop,foo
Jim K6JWN
Hi,
Cheers,
Matt
G4RKY
Node 2250
Jim Nessen K6JWN
Hi All
Makes sense to me as well, i had a few 500 series macros set up to connect most commoly used nodes/destinations on the fly and ran into the same issue
now i know what to do to fix it… thanks again
Thanks in Advance
Bob Brown, NØEUH
Kansas City Metro Area
http://sm0kenet.net
http://byrg.net
http://kcdstar.byrg.net
Frank Lloyd Wright - “TV is chewing gum for the eyes.”
Jim WB6NIL
941 = cop,something
943 = cop,foo
Jim K6JWN
Hi,
Cheers,
Matt
G4RKY
Node 2250
Jim Nessen K6JWN
