Does anyone have a wiring diagram for the DR-1X yaesu repeater to URI via the external ports? On latest firmware.
Mike
Kb8zgl
Sent from my iPhone
Mike
Kb8zgl
Sent from my iPhone
I’m trying to do this, too. Let me know what you learned.
Rod wb9kmo@gmail.com
Are you going to run the DR1x in AMS mode or fixed FM?
also interested. I don’t think, without some modifications or add-on boards that you can run in AMS, only straight FM. I may be (probably am) wrong, though.
No, you’re correct. Also be aware that you will not be able to use Allstar with C4FM, only analog
Yes and no, Allstar will only handle FM, but repeater will do both. With the way I set it up, the digital does not pass to Allstar and runs local on repeater.
