I did. There is no mention in that announcement of changing config files to point to pttlink.org rather than allstarlink.org. That is why I asked for clarity.
Just to clarify, Allstarlink’s registration system is fully operational. Nodes should operate as before. There is no need for repeater owners / node operators to change anything.
The users don’t need to make any changes for their nodes to continue to work with the official ASL® servers.
The notices you are seeing elsewhere (to make configuration changes) are from people running a separate network which is not affiliated with ASL, Inc. If you choose to make changes to your node to operate under a different network, you are doing so at your own risk.
Anything you see on a website or email group that doesn’t have “allstarlink.org” or “allstarlink.net” as a domain is not official ASL content. This includes posts and content shown at pttlink.org and keekles.org. Again, ASL Community is the only official AllStarLink® communications exchange.
To clarify, as soon as a node’s internet provider updates their DNS, the site will start working as before. Most internet providers updated everything within the hour of the cutover. Try rebooting your node. Often that forces a new lookup. If you have any problems. please reach out to us.
There is no coup. The five all volunteer board members that have been guiding the organization are still here.
Pete Elke /WI6H - President
Todd Lesser /KM6RPT - Secretary
David Shaw /WB6WTM - Treasurer
Tim Sawyer /WD6AWP - Vice President
Kevin Custer /W3KKC - Board Member
DNS was changed to connect all Allstar existing nodes to our new back-end infrastructure (as noted in our announcement).
*** No changes to your node are required for it to continue to work with AllstarLink. We have had reports of DNS servers and nodes caching the the old servers. If you find your node is stuck you may have to flush the DNS cache with a reboot of the node or other DNS caching device (some home routers etc). At this point in time 90%+ of the systems have made the switch cleanly.
