DNS Problems nodes.allstarlink.org
Seems the DNS nodes.allstarlink.org is not working.
root@58823:/tmp# asl-node-lookup 58823
SRV (_iax._udp.58823.nodes.allstarlink.org)
No SRV record
A (58823.nodes.allstarlink.org)
No address (A) record
TXT (58823.nodes.allstarlink.org)
No TXT record
RPT LOOKUP (58823)
radio@127.0.0.1/58823,NONE
Seems to also be affecting SharkRF M1KE from connecting to nodes as well.
I am looking into this right now.
All should be better now.
All good now! Thank you!!!
Cannot load. 6:26 central
I installed some new code yesterday that clearly is not behaving. All should be working now. If this happens again I will revert back to the older code.
