DNS issues with Dial
/var/log/asterisk/messages:
[Jan 30 23:45:03] NOTICE[675] dnsmgr.c: Managed DNS entries will be
refreshed every 300 seconds.
[Jan 30 23:45:03] NOTICE[675] cdr.c: CDR simple logging enabled.
[Jan 30 23:45:03] NOTICE[675] loader.c: 57 modules will be loaded.
[Jan 30 23:45:03] WARNING[675] acl.c: Unable to lookup 'callcentric.com'
[Jan 30 23:45:04] WARNING[711] chan_sip.c: No such host: callcentric.com
[Jan 30 23:45:04] WARNING[711] chan_sip.c: Probably a DNS error for
registration to 1777......101@callcentric.com, trying REGISTER again
(after 60 seconds)
[Jan 30 23:45:04] WARNING[675] pbx.c: Unable to register extension
'_1.', priority 1 in 'allstar-sys', already in use
[Jan 30 23:45:04] NOTICE[696] app_rpt.c: Normal Repeater Init 29626
[Jan 30 23:45:04] NOTICE[696] app_rpt.c: Normal Repeater Init 29627
[Jan 30 23:45:04] NOTICE[696] app_rpt.c: Normal Repeater Init 1001
[Jan 30 23:45:05] WARNING[718] chan_usbradio.c: Loaded parameters from
usbradio_tune_usb29627.conf for device usb29627 .
[Jan 30 23:45:05] WARNING[715] chan_usbradio.c: Possibly stuck USB
read channel. [usb29627]
[Jan 30 23:45:05] WARNING[715] chan_usbradio.c: Nope, USB read channel
[usb29627] wasn't stuck after all.
[Jan 30 23:45:05] NOTICE[716] chan_simpleusb.c: Assigned USB device
4-2:1.0 to simpleusb channel usb29626
[Jan 30 23:45:05] WARNING[716] chan_simpleusb.c: Loaded parameters
from simpleusb_tune_usb29626.conf for device usb29626 .
[Jan 30 23:45:05] WARNING[719] chan_usbradio.c: Loaded parameters from
usbradio_tune_usb1001.conf for device usb1001 .
[Jan 30 23:45:05] WARNING[717] chan_usbradio.c: Possibly stuck USB
read channel. [usb1001]
[Jan 30 23:45:05] WARNING[717] chan_usbradio.c: Nope, USB read channel
[usb1001] wasn't stuck after all.
Using nslookup -
# nslookup callcentric.com
Server: 216.228.160.3
Address: 216.228.160.3#53
Non-authoritative answer:
Address: 204.11.192.159
Address: 204.11.192.169
Address: 204.11.192.163
Address: 204.11.192.171
Address: 204.11.192.160
Address: 204.11.192.170
Address: 204.11.192.161
If I run
asterisk -rx "sip reload"
everything is fine with the sip connection - now shows the peer is
registered and I can make calls - autopatch
asterisk -rx "sip show peers"
Name/username Host Dyn Nat ACL Port Status
callcentric/1777......101 204.11.192.170 5080
   Unmonitored
where as before I did the sip reload, it shows the port as 0
Anyone come across this type of issue?
I tried disabling the dnsmgr, but did not change anything.
73's
Mark KC7DMF
I had similar issues during boot when I started using Dial on my RPi. I
found that Asterisk was starting too quickly before other needed processes
had initialized. By putting a "sleep 30" statement in the asterisk start RC
script, all issues were solved, even the failure to register Echolink. It
appeared that the network hadn't fully initialized before Asterisk was
trying to do DNS lookups. In my case, I'm using DHCP on the RPi and the home
router forces the same address to it each time.
73, Jim, KY2D, node 2396
-----Original Message-----
[mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Mark Johnston
Sent: Sunday, January 31, 2016 2:55 AM
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] DNS issues with Dial
registration to 1777......101@callcentric.com, trying REGISTER again (after
60 seconds) [Jan 30 23:45:04] WARNING[675] pbx.c: Unable to register
extension '_1.', priority 1 in 'allstar-sys', already in use [Jan 30
23:45:04] NOTICE[696] app_rpt.c: Normal Repeater Init 29626 [Jan 30
23:45:04] NOTICE[696] app_rpt.c: Normal Repeater Init 29627 [Jan 30
23:45:04] NOTICE[696] app_rpt.c: Normal Repeater Init 1001 [Jan 30
[Jan 30 23:45:05] WARNING[715] chan_usbradio.c: Possibly stuck USB read
channel. [usb29627] [Jan 30 23:45:05] WARNING[715] chan_usbradio.c: Nope,
USB read channel [usb29627] wasn't stuck after all.
[Jan 30 23:45:05] WARNING[716] chan_simpleusb.c: Loaded parameters from
[Jan 30 23:45:05] WARNING[717] chan_usbradio.c: Possibly stuck USB read
channel. [usb1001] [Jan 30 23:45:05] WARNING[717] chan_usbradio.c: Nope, USB
read channel [usb1001] wasn't stuck after all.
Using nslookup -
If I run
Status
   Unmonitored
73's
Mark KC7DMF
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to
the bottom of the page. Enter your email address and press the "Unsubscribe
or edit options button"
