Hello,
I am having trouble receiving audio into Allstar. I can hear audio from Allstar. Tested audio on pins 21 and 20 on the connector going into the URI and audio is coming in perfectly. That leaves me with the problem of getting the audio through the DMK Uri to the computer and on to Allstar.
Made up a loop back cable for the Uri and received the following and not sure what to think about the results I received. To me it appears that the audio is in the tank and not working but I am not sure of all the other results. Any input will be appreciated from anyone having had to do the same test.
Upon opening the Uri I get the following:
Found CM119 USB Radio Interface at 002/003 (This is the bus and port the Uri appears on}
Unable to re-open DSP device 1: /dev/dsp1
The Left Channel Test and Right Channel test are all like what is shown below only with differing frequencies.
Level at 1004.0 Hz: 0.0 mV (RMS) 0.0 mV (P-P)
Level at 204.0 Hz: 0.0 mV (RMS) 0.0 mV (P-P) (Same results for test for test 3 to 99)
Test T
Enter your selection: T
Testing digital I/O (PTT,COR,TONE and GPIO)…
Digital I/O passed!!
Testing Analog at 204 (and 700) Hz…
Analog level on left channel for 204.0 Hz (0.0) is out of range!!
Must be between 440.0 and 660.0
Analog level on right channel for 700.0 Hz (0.0) is out of range!!
Testing Analog at 504 (and 700) Hz…
Analog level on left channel for 504.0 Hz (0.0) is out of range!!
Testing Analog at 1004 (and 700) Hz…
Analog level on left channel for 1004.0 Hz (0.0) is out of range!!
Testing Analog at 2004 (and 700) Hz…
Analog level on left channel for 2004.0 Hz (0.0) is out of range!!
Testing Analog at 3004 (and 700) Hz…
Analog level on left channel for 3004.0 Hz (0.0) is out of range!!
Testing Analog at 5004 (and 700) Hz…
Analog level on left channel for 5004.0 Hz (0.0) is out of range!!
Must be between 93.6 and 140.4
Testing Analog at 700 (and 204) Hz…
Analog level on left channel for 700.0 Hz (0.0) is out of range!!
Analog level on right channel for 204.0 Hz (0.0) is out of range!!
Testing Analog at 700 (and 504) Hz…
Analog level on right channel for 504.0 Hz (0.0) is out of range!!
Testing Analog at 700 (and 1004) Hz…
Test i
Enter your selection:i
Thank you for your time! Very much appreciated.
