Any info about the wiring to minidin 6pind yaesu ?
The wiring is same as Kenwood TM-D700 and Icom IC880H (i have used both radios with same cable wiring as Yaesu 8800)
Go to page 10: http://www.yaesu.com/downloadFile.cfm?FileID=754&FileCatID=150&FileName=FT-8900R_Spanish.pdf&FileContentType=application%2Fpdf
If using URI FOB and COS from radio, use carrierfrom=usb
Make your own cable, or order at Yaesu FT-8800 Radio to URI
ohnosec.org
I seem to remember using my 8900 for a link once and found that the COS output was exactly that, simply an output from the carrier squelch.
What I am saying is that the COS output is not subject to CTCSS, so even if the tone decoder in the 8900 is set up for decode, the COS line still just follows the carrier squelch.
Matt
G4RKY
Currently in Alcaniz!
Go to page 10: [http://www.yaesu.com/downloadFile.cfm?FileID=754&FileCatID=150&FileName=FT%2D8900R%5FSpanish.pdf&FileContentType=application%2Fpdf](http://www.yaesu.com/downloadFile.cfm?FileID=754&FileCatID=150&FileName=FT%2D8900R%5FSpanish.pdf&FileContentType=application%2Fpdf) If using URI FOB and COS from radio, use carrierfrom=usb Make your own cable, or order at [http://uricables.com/Yaesu-FT8800R.html](http://uricables.com/Yaesu-FT8800R.html) On 6/24/2012 5:08 AM, ea8ee wrote:
_______________________________________________ App_rpt-users mailing list App_rpt-users@ohnosec.org [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
I Ordered the cable to ke6pcv but the answer arrived with this email is not registered
2012/6/26 Matt Beasant g4rky@yahoo.co.uk
Matt
G4RKY
