DMK Engineering URI stops working after Software update
I’m trying to figure out why my node stopped working after I did a software update. I am using a Raspberry Pi 5 with an SSD drive. The URI is a DMK Engineering with a green light and no heartbeat. I checked, and the Pi does see URI. I connected the URI to a different node, and it works fine. Is this a configuration issue or a driver issue?
Here are the packages that were updated on 11/03/25.
  • allmon3
  • autoconf
  • automake
  • autopoint
  • autotools-dev
  • bluez-firmware
  • dahdi-dkms
  • dahdi-linux
  • dahdi-source
  • debhelper
  • dh-autoreconf
  • dh-strip-nondeterminism
  • dwz
  • firmware-atheros
  • firmware-brcm80211
  • firmware-intel-graphics
  • firmware-intel-misc
  • firmware-libertas
  • firmware-marvell-prestera
  • firmware-mediatek
  • firmware-misc-nonfree
  • firmware-nvidia-graphics
  • firmware-realtek
  • gettext
  • intltool-debian
  • libarchive-cpio-perl
  • libarchive-zip-perl
  • libc-bin
  • libc-dev-bin
  • libc-devtools
  • libc-l10n
  • libc6
  • libc6-dbg
  • libc6-dev
  • libdebhelper-perl
  • libdtovl0
  • libfile-stripnondeterminism-perl
  • libgpiolib0
  • libltdl-dev
  • libmail-sendmail-perl
  • libssl3
  • libsub-override-perl
  • libsys-hostname-long-perl
  • libtool
  • linux-headers-6.12.47+rpt-common-rpi
  • linux-headers-6.12.47+rpt-rpi-2712
  • linux-headers-6.12.47+rpt-rpi-v8
  • linux-headers-rpi-2712
  • linux-headers-rpi-v8
  • linux-image-6.12.47+rpt-rpi-2712
  • linux-image-6.12.47+rpt-rpi-v8
  • linux-image-rpi-2712
  • linux-image-rpi-v8
  • linux-kbuild-6.12.47+rpt
  • linux-libc-dev
  • locales
  • m4
  • openssl
  • po-debconf
  • raspberrypi-sys-mods
  • raspi-firmware
  • raspi-utils
  • raspi-utils-core
  • raspi-utils-dt
  • raspi-utils-eeprom
  • raspi-utils-otp
  • raspinfo
  • rpi-eeprom
Nov 3, 2025, 11:04 PM 8 packages
undefined ----
  • bind9-dnsutils
  • bind9-host
  • bind9-libs
  • libtiff6
  • libxslt1.1
  • linux-headers-6.1.0-40-arm64
  • linux-headers-6.1.0-40-common
  • linux-headers-arm64
Dave KA9WXN
I have found a resolution! For some reason, when the system finished its reboot after the update, it changed the URI port assignment in the system configuration.
The fix was straightforward:
Find the new URI device path: Run the command:
Bash
ls -l /dev/usb/
This displayed the URI device and port information, showing the new path.
Update the Allstarlink configuration: Edit the /etc/asterisk/simpleusb.conf file to reflect the correct device path for the node. (e.g., changing device = /dev/usb/hiddev0 to the new path found in step 1.)
Restart Asterisk: Apply the changes by restarting the Asterisk service:
Bash
sudo systemctl restart asterisk
After these steps, the URI's heartbeat resumed, and the node is working again! Hope this helps anyone else encountering similar issues after a major kernel or firmware update on a Raspberry Pi running Allstarlink.
