Occasionally someone will connect to our club repeater node (an incoming connection) and we wish to disconnect them. However, we are unable to do so using *1[node number] from our side. Or more accurately, we enter *1[node number] and watch them disappear on Allmon only to see them automatically reconnect moments later. I have personally tested this by making a connection using my own node and confirmed it.
Is there a setting that I am missing in the config? What might cause us to be unable to disconnect incoming connections?
The DTMF for ilink commands may vary on your node. ASL defaults are:
; Remove the comments (the ; ) to enable.
; 806 = ilink,6 ; Disconnect all links
; 807 = ilink,7 ; Last Node to Key Up
; 808 = ilink,8 ; Connect specified link -- local monitor only
; 809 = ilink,9,1999,"Testing" ; would send a text message to node 1999 replace 1999 with 0 for all connected nodes
; 810 = ilink,10 ; Disconnect all RANGER links (except permalinks)
; 811 = ilink,11 ; Disconnect a previously permanently connected link
; 812 = ilink,12 ; Permanently connect specified link -- monitor only
; 813 = ilink,13 ; Permanently connect specified link -- tranceive
; 815 = ilink,15 ; Full system status (all nodes)
; 816 = ilink,16 ; Reconnect links disconnected with "disconnect all links"
; 817 = ilink,17 ; MDC test (for diag purposes)
; 818 = ilink 18 ; Permanently Connect specified link -- local monitor only
