Allmon3 has a feature to disconnect all nodes at once. I’d like to do this with DTMF. Can this be done?
de Steve N6VL
de Steve N6VL
Yes, but not by default.
in rpt.conf, under the functions stanza, are a bunch of codes starting with 8. One of those, *806, maps to ilink,6, which disconnects all links.
This is commented out, as well as all the 9’s that reference cop commands, presumably to avoid drive-by DTMFers dropping all links on a repeater and doing unwanted things to your node(s), such as issuing cop,4 to blast a 1k tone to all connected nodes for 8 hours straight… Nope, that didn’t happen to me recently or anything…
You can uncomment this line and/or change it to something else that isn’t in use, then reload app_rpt or restart Asterisk to make it go live.
The default line is:
; 806 = ilink,6 ; Disconnect all links
@N2DYI
Yes it works great!!!
But I expected a verification in telemetry. Maybe I’m too picky? But it does get the job done.
You should get a double beep for acknowledgement of a successful command.
But no Allison feedback like some functions.
