Disable the TXENA
Is it possible to disable the T X E N A announcement when re enabling the transmitter? I have a script which disables the transmitter and re-enables every time that I switch channels on my remote base. It is sort of annoying that it goes throughout all links that have telemetry enabled.
Skyler
Are you sure you need to disable the TX? I’m pretty sure none of the telemetry comes out of the remote side.
Skyler
Tim
When I do a playback from another LOCAL node, (sharing the same rpt.conf), the remote base will play the audio file over it’s transmitter. I was able to solve this problem by disabling the transmitter for the duration of the script so that it does not play any of the telemetry when switching channels.
Modifying app_rpt.c to replace “RPTENA” with “” and then recompiling asterisk did solve the issue so it won’t announce anything when I re activate the transmitter.
Skyler KDØWHB
Skyler
Tim
Skyler Fennell
amsatnet.info
KDØWHB
If it was actually in remote base mode it wouldn’t do this…
Skyler
Tim
Skyler Fennell
amsatnet.info
KDØWHB
I have my node configured as a remote base node and when it is connected
to another node, and the other node does a PLAYBACK, the remote base hears it and retransmitts it. Is that normal?
kd0whb
On Mon, May 2, 2016 at 5:44 PM, Skyler F electricity440@gmail.com wrote:
I have my node configured as a remote base node and when it is connected to another node, and the other node does a PLAYBACK, the remote base hears it and retransmitts it. Is that normal??
Sent from my iPhone
Skyler KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Skyler Fennell
amsatnet.info
KDØWHB
The reason I am asking this is because my remote base has custom scripts that announce the channel, and use the playback command to announce the new channel. The problem is that the playback command also announces out of the remote base transmitter.
kd0whb
Skyler Fennell
amsatnet.info
KDØWHB
Sent from my iPhone
Skyler KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Skyler Fennell
amsatnet.info
KDØWHB
It will play it back locally but not out the remote base transmitter. Mine is the Doug hall rbi1
Well… Mine is set up as a remote base, and when I hook another node into it, and run the playback command, the remote base transmits it.
Sent from my iPhone
Sent from my iPhone
Skyler KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Skyler Fennell
amsatnet.info
KDØWHB
What about using the localplay command rather than the playback command?
Skyler KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Tim
Then I won’t be able to hear the telemetry with the node that has just connected to the remote base
Skyler KDØWHB
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Hi Skyler,
Not sure if you ever got a solution for this issue. I was thinking along the lines Corey was. If you set this node up as a traditional “Dumb” remote base, then when you go into Command Mode (*4) of that node, the remote base will not transmit. That way you don’t have to use the part of your script the enables and disables your transmitter. Here’s a overview of how to make it a traditional remote base:
rpt.conf:
[1234]
rxchannel = SimpleUSB/usb ; Set for your receive channel / device
remote=y ; Set as "Dumb" node, as your script will handle the channel changes
functions=functions-remote ; Wherever your functions live
phone_functions=functions-remote ; Wherever your functions live
[nodes] 1234 = [radio@127.0.0.1/1234,NONE,y](http://radio@127.0.0.1/1234,NONE,y) ; Remote base node
Monty
Skyler Fennell
amsatnet.info
KDØWHB
Skyler KDØWHB
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Thank you Monty, first, I meant rptena (my version says txena) but I haven’t been able to fix that issue, but isn’t a really big deal.
If I can run shell scrips from a remote base node, I’m all for using that functionality. I haven’t been able to get cmd to work from it, however.
Remote VHF - 42622
Remote UHF - 40764
Monty
Skyler Fennell
amsatnet.info
KDØWHB
Skyler KDØWHB
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Hi again everyone.
I already have one node up and running, but wanted to create another 2. One for work that I can leave running and one for in the car.
How do i request more nodes via my account ? If I go to “request nodes”, it shows my current node and then gives me a comments box to write in, however it also states “The “Comments” field (below) is for comments regarding THIS node request only. If you want additional node numbers, do them as separate requests!!”
As such i’m a little confused as to how to request a couple of extra node numbers.
Yours,
Gareth
Just press the “Submit Request” button at the bottom.
Then, do the process again. Kevin
On 9/30/2016 11:46 AM, Gareth Jackson
wrote:
Hi again everyone.
When in “Remote Base” mode, the node is essentially dead, will not respond or do any commands unless another node is connected to it. Maybe that is why you are having issues?
Remote VHF - 42622
Remote UHF - 40764
On Thursday, September 29, 2016, Monty monty@ke7jvx.com wrote:
Hi Skyler,
rpt.conf:
[1234]
Skyler Fennell
amsatnet.info
KDØWHB
Monty
Monty
Skyler Fennell
amsatnet.info
KDØWHB
Skyler KDØWHB
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Correct, but remote base mode will not execute certain commands that normal mode will execute like the cop functions. How am I supposed to steer my custom radio in remote base mode, if I can’t execute custom commands. Thats why the node I set up on Blue Mountain out of a 40 channel GM300 is built off of a normal node.
Skyler
Monty
Remote VHF - 42622
Remote UHF - 40764
Hi Skyler,
rpt.conf:
[1234]
Skyler Fennell
amsatnet.info
KDØWHB
Monty
Skyler Fennell
amsatnet.info
KDØWHB
Skyler KDØWHB
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Skyler
Tim
Skyler Fennell
amsatnet.info
KDØWHB
