Previous to ASL3, one could select verbosity level 9 and see (within the ASL CLI) rx and tx states in real time. I can’t find how to do that with ASL3. The docs haven’t showed me the way either
asl-menu
, then Node Settings > Allstar Node Setup Menu > Update Node ##### > Interface Tune CLI
It’s a hub radioless node. Previous to ASL3 I could see what all connected nodes were up to. As there is no interface, there is nothing to “tune”
I thought you were wanting to see the live COS/COR/PTT etc logic of your node interface.
I’m not sure what you’re wanting to do with the CLI, as this information would normally be viewed from Allmon3.
I run several nodes, remotely located and connected to a central hub. I don’t use Allmon, I use Supermon but regardless, I’m trying to track down the source of something that is keying all nodes about 30 seconds after the last activity on any node. Well, more like kerchunking than keying. Supermon doesn’t respond quickly enough. I want to monitor COS on ANY connected node in an effort to ID the source. That used to be possible in the Asterisk CLI previous to ASL3
Does debug provide the info I need (see above)?
