Anyone try setting this up yet?
Used to use this with ACID just fine
Installed ezstream, and Lame -
shows it's running
1124 ? S 0:00 /bin/sh -c /usr/bin/lame --preset cbr 16 -r -m m
-s 8 --bitwidth 16 - - | /usr/bin/ezstream -qvc /etc/ezstream1001.xml
I enabled this module, thinking thats what it needed
load => app_ices.so ; Encode and Stream via
icecast and ices
;modules.conf
autoload=no
; Applications
noload => app_adsiprog.so ; Asterisk ADSI Programming Application
noload => app_alarmreceiver.so ; Alarm Receiver for Asterisk
noload => app_amd.so ; Answering Machine Detection Application
load => app_authenticate.so ; Authentication Application
noload => app_cdr.so ; Tell Asterisk to not maintain a CDR for
noload => app_chanisavail.so ; Check channel availability
noload => app_channelredirect.so ; Channel Redirect
load => app_chanspy.so ; Listen to the audio of an active channel
noload => app_controlplayback.so ; Control Playback Application
noload => app_dahdibarge.so ; Barge in on channel application
noload => app_dahdiras.so ; DAHDI RAS Application
noload => app_dahdiscan.so ; Scan Zap channels application
noload => app_db.so ; Database Access Functions
load => app_dial.so ; Dialing Application
noload => app_dictate.so ; Virtual Dictation Machine
noload => app_directed_pickup.so ; Directed Call Pickup Application
noload => app_directory.so ; Extension Directory
noload => app_disa.so ; DISA (Direct Inward System Access) Appli
noload => app_dumpchan.so ; Dump Info About The Calling Channel
noload => app_echo.so ; Simple Echo Application
load => app_exec.so ; Executes dialplan applications
noload => app_externalivr.so ; External IVR Interface Application
noload => app_festival.so ; Simple Festival Interface
noload => app_flash.so ; Flash channel application
noload => app_followme.so ; Find-Me/Follow-Me Application
noload => app_forkcdr.so ; Fork The CDR into 2 separate entities
noload => app_getcpeid.so ; Get ADSI CPE ID
noload => app_gps.so ; GPS interface module
noload => app_hasnewvoicemail.so ; Indicator for whether a voice mailbox ha
load => app_ices.so ; Encode and Stream via icecast and ices
noload => app_image.so ; Image Transmission Application
noload => app_lookupblacklist.so ; Look up Caller*ID name/number from black
noload => app_lookupcidname.so ; Look up CallerID Name from local databas
load => app_macro.so ; Extension Macros
noload => app_meetme.so ; MeetMe conference bridge
noload => app_milliwatt.so ; Digital Milliwatt (mu-law) Test Applicat
noload => app_mixmonitor.so ; Mixed Audio Monitoring Application
noload => app_morsecode.so ; Morse code
noload => app_mp3.so ; Silly MP3 Application
noload => app_nbscat.so ; Silly NBS Stream Application
noload => app_page.so ; Page Multiple Phones
noload => app_parkandannounce.so ; Call Parking and Announce Application
load => app_playback.so ; Sound File Playback Application
noload => app_privacy.so ; Require phone number to be entered, if n
noload => app_queue.so ; True Call Queueing
noload => app_radbridge.so ; Radio Bridging interface module
noload => app_random.so ; Random goto
noload => app_readfile.so ; Stores output of file into a variable
noload => app_read.so ; Read Variable Application
noload => app_realtime.so ; Realtime Data Lookup/Rewrite
noload => app_record.so ; Trivial Record Application
load => app_rpt.so ; Radio Repeater/Remote Base Application
noload => app_sayunixtime.so ; Say time
load => app_senddtmf.so ; Send DTMF digits Application
noload => app_sendtext.so ; Send Text Applications
noload => app_setcallerid.so ; Set CallerID Application
noload => app_setcdruserfield.so ; CDR user field apps
noload => app_settransfercapability.so ; Set ISDN Transfer Capability
noload => app_sms.so ; SMS/PSTN handler
noload => app_softhangup.so ; Hangs up the requested channel
noload => app_speech_utils.so ; Dialplan Speech Applications
noload => app_stack.so ; Stack Routines
load => app_system.so ; Generic System() application
noload => app_talkdetect.so ; Playback with Talk Detection
noload => app_test.so ; Interface Test Application
load => app_transfer.so ; Transfer
noload => app_url.so ; Send URL Applications
noload => app_userevent.so ; Custom User Event Application
noload => app_verbose.so ; Send verbose output
noload => app_voicemail.so ; Comedian Mail (Voicemail System)
noload => app_waitforring.so ; Waits until first ring after time
noload => app_waitforsilence.so ; Wait For Silence
noload => app_while.so ; While Loops and Conditional Execution
noload => app_zapateller.so ; Block Telemarketers with Special Informa
; CDR
noload => cdr_csv.so ; Comma Separated Values CDR Backend
noload => cdr_custom.so ; Customizable Comma Separated Values CDR
noload => cdr_manager.so ; Asterisk Manager Interface CDR Backend
; Channels
noload => chan_agent.so ; Agent Proxy Channel
noload => chan_alsa.so ; ALSA Console Channel Driver
noload => chan_beagle.so ; Beagleboard Radio Interface Channel Driver
load => chan_dahdi.so ; DAHDI Telephony
noload => chan_echolink.so ; echolink channel driver
noload => chan_features.so ; Feature Proxy Channel
noload => chan_gtalk.so ; Gtalk Channel Driver
load => chan_iax2.so ; Inter Asterisk eXchange (Ver 2)
load => chan_local.so ; Local Proxy Channel (Note: used internal
noload => chan_oss.so ;
noload => chan_phone.so ;
load => chan_simpleusb.so ; Simple USB Radio Interface Channel Drive
load => chan_sip.so ; Session Initiation Protocol (SIP)
noload => chan_tlb.so ; TheLinkBox channel driver
load => chan_usbradio.so ; USB Console Channel Driver
noload => chan_usrp.so ; USRP Channel Module
noload => chan_voter.so ; radio Voter channel driver
; Codecs
; CODEC AUDIO QUALITY BANDWIDTH (including IP and Ethernet
headers)
; ULAW best 87 kilobits per second (kbps)
; ADPCM good 55 kbps
; GSM mediocre 36 kbps
; g726aal2
; ilbc
load => codec_adpcm.so ; Adaptive Differential PCM Coder/Decoder
load => codec_alaw.so ; A-law Coder/Decoder
load => codec_a_mu.so ; A-law and Mulaw direct Coder/Decoder
noload => codec_dahdi.so ; Generic DAHDI Transcoder Codec Translato
load => codec_g726.so ; ITU G.726-32kbps G726 Transcoder
load => codec_gsm.so ; GSM Coder/Decoder
load => codec_ulaw.so ; mu-Law Coder/Decoder
noload => codec_ilbc.so ;
; Formats
load => format_g723.so ; G.723.1 Simple Timestamp File Format
load => format_g726.so ; Raw G.726 (16/24/32/40kbps) data
load => format_g729.so ; Raw G729 data
load => format_gsm.so ; Raw GSM data
load => format_h263.so ; Raw H.263 data
load => format_h264.so ; Raw H.264 data
load => format_ilbc.so ; Raw iLBC data
noload => format_jpeg.so ; JPEG (Joint Picture Experts Group) Image
load => format_pcm.so ; Raw/Sun uLaw/ALaw 8KHz (PCM,PCMA,AU), G.
load => format_sln.so ; Raw Signed Linear Audio support (SLN)
load => format_vox.so ; Dialogic VOX (ADPCM) File Format
load => format_wav_gsm.so ; Microsoft WAV format (Proprietary GSM)
load => format_wav.so ; Microsoft WAV format (8000Hz Signed Line
; Functions
load => func_base64.so ; base64 encode/decode dialplan functions
load => func_callerid.so ; Caller ID related dialplan function
load => func_cdr.so ; CDR dialplan function
load => func_channel.so ; Channel information dialplan function
load => func_curl.so ; Load external URL
load => func_cut.so ; Cut out information from a string
load => func_db.so ; Database (astdb) related dialplan functi
load => func_enum.so ; ENUM related dialplan functions
load => func_env.so ; Environment/filesystem dialplan function
load => func_global.so ; Global variable dialplan functions
load => func_groupcount.so ; Channel group dialplan functions
load => func_language.so ; Channel language dialplan function
load => func_logic.so ; Logical dialplan functions
load => func_math.so ; Mathematical dialplan function
load => func_md5.so ; MD5 digest dialplan functions
load => func_moh.so ; Music-on-hold dialplan function
load => func_rand.so ; Random number dialplan function
load => func_realtime.so ; Read/Write values from a RealTime reposi
noload => func_sha1.so ; SHA-1 computation dialplan function
noload => func_strings.so ; String handling dialplan functions
noload => func_timeout.so ; Channel timeout dialplan functions
noload => func_uri.so ; URI encode/decode dialplan functions
; PBX
noload => pbx_ael.so ; Asterisk Extension Language Compiler
load => pbx_config.so ; Text Extension Configuration
noload => pbx_dundi.so ; Distributed Universal Number Discovery (
noload => pbx_loopback.so ; Loopback Switch
noload => pbx_realtime.so ; Realtime Switch
noload => pbx_spool.so ; Outgoing Spool Support
; Resources
load => res_adsi.so ; ADSI Resource
noload => res_agi.so ; Asterisk Gateway Interface (AGI)
noload => res_clioriginate.so ; Call origination from the CLI
noload => res_convert.so ; File format conversion CLI command
noload => res_crypto.so ; Cryptographic Digital Signatures
load => res_features.so ; Call Features Resource
load => res_indications.so ; Indications Resource
noload => res_jabber.so ; AJI - Asterisk Jabber Interface
noload => res_monitor.so ; Call Monitoring Resource
noload => res_musiconhold.so ; Music On Hold Resource
noload => res_smdi.so ; Simplified Message Desk Interface (SMDI)
noload => res_snmp.so ; SNMP [Sub]Agent for Asterisk
noload => res_speech.so ; Generic Speech Recognition API
[global]
/var/log/asterisk/messages;
[Oct 8 08:44:24] NOTICE[1278] cdr.c: CDR simple logging enabled.
[Oct 8 08:44:24] NOTICE[1278] indications.c: Removed default indication
country 'us'
[Oct 8 08:44:24] WARNING[1278] chan_dahdi.c: Ignoring switchtype
[Oct 8 08:44:24] WARNING[1278] chan_dahdi.c: Ignoring signalling
[Oct 8 08:44:24] WARNING[1278] chan_dahdi.c: Ignoring rxwink
[Oct 8 08:44:24] NOTICE[1278] chan_iax2.c: Ignoring bindport on reload
[Oct 8 08:44:24] NOTICE[1278] chan_iax2.c: Ignoring bindaddr on reload
[Oct 8 08:44:25] WARNING[1278] acl.c: is not a valid IP
[Oct 8 08:44:25] WARNING[714] chan_sip.c: insecure=very at line 31 is
deprecated; use insecure=port,invite instead
[Oct 8 08:47:46] NOTICE[683] cdr.c: CDR simple logging enabled.
[Oct 8 08:47:46] NOTICE[683] loader.c: 56 modules will be loaded.
[Oct 8 08:47:46] WARNING[683] acl.c: is not a valid IP
[Oct 8 08:47:46] WARNING[683] acl.c: Unable to lookup 'callcentric.com'
[Oct 8 08:47:46] WARNING[714] chan_sip.c: No such host: callcentric.com
[Oct 8 08:47:46] WARNING[714] chan_sip.c: Probably a DNS error for
registration to 17772150287101@callcentric.com, trying REGISTER again
(after 20 seconds)
[Oct 8 08:47:46] NOTICE[699] app_rpt.c: Normal Repeater Init 29626
[Oct 8 08:47:46] NOTICE[699] app_rpt.c: Normal Repeater Init 29627
[Oct 8 08:47:46] NOTICE[699] app_rpt.c: Normal Repeater Init 1001
[Oct 8 08:47:47] WARNING[722] chan_usbradio.c: Loaded parameters from
usbradio_tune_usb1001.conf for device usb1001 .
[Oct 8 08:47:47] WARNING[720] chan_usbradio.c: Possibly stuck USB read
channel. [usb1001]
[Oct 8 08:47:47] WARNING[720] chan_usbradio.c: Nope, USB read channel
[usb1001] wasn't stuck after all.
[Oct 8 08:47:47] NOTICE[719] chan_simpleusb.c: Assigned USB device 5-2:1.0
to simpleusb channel usb29626
[Oct 8 08:47:47] WARNING[719] chan_simpleusb.c: Loaded parameters from
simpleusb_tune_usb29626.conf for device usb29626 .
[Oct 8 08:47:47] NOTICE[721] chan_usbradio.c: Assigned USB device 5-2:1.0
to usbradio channel usb29627
[Oct 8 08:47:47] WARNING[721] chan_usbradio.c: Loaded parameters from
usbradio_tune_usb29627.conf for device usb29627 .
[Oct 8 08:47:47] WARNING[721] chan_usbradio.c: Unable to re-open DSP
device 2 (usb29627): Device or resource busy
[Oct 8 08:48:06] NOTICE[714] chan_sip.c: -- Registration for '
17772150287101@callcentric.com' timed out, trying again (Attempt #1)
[Oct 8 08:59:15] NOTICE[673] cdr.c: CDR simple logging enabled.
[Oct 8 08:59:15] NOTICE[673] loader.c: 57 modules will be loaded.
[Oct 8 08:59:15] WARNING[673] acl.c: is not a valid IP
[Oct 8 08:59:15] WARNING[673] acl.c: Unable to lookup 'callcentric.com'
[Oct 8 08:59:15] WARNING[711] chan_sip.c: No such host: callcentric.com
[Oct 8 08:59:15] WARNING[711] chan_sip.c: Probably a DNS error for
(after 20 seconds)
[Oct 8 08:59:15] NOTICE[695] app_rpt.c: Normal Repeater Init 29626
[Oct 8 08:59:15] NOTICE[695] app_rpt.c: Normal Repeater Init 29627
[Oct 8 08:59:15] NOTICE[695] app_rpt.c: Normal Repeater Init 1001
[Oct 8 08:59:15] WARNING[718] chan_usbradio.c: Loaded parameters from
[Oct 8 08:59:15] WARNING[715] chan_usbradio.c: Possibly stuck USB read
channel. [usb29627]
[Oct 8 08:59:16] WARNING[715] chan_usbradio.c: Nope, USB read channel
[usb29627] wasn't stuck after all.
[Oct 8 08:59:16] NOTICE[719] chan_usbradio.c: Assigned USB device 5-2:1.0
to usbradio channel usb1001
[Oct 8 08:59:16] NOTICE[716] chan_simpleusb.c: Assigned USB device 5-2:1.0
[Oct 8 08:59:16] WARNING[716] chan_simpleusb.c: Loaded parameters from
[Oct 8 08:59:16] WARNING[719] chan_usbradio.c: Loaded parameters from
[Oct 8 08:59:16] WARNING[719] chan_usbradio.c: Unable to re-open DSP
device 2 (usb1001): Device or resource busy
[Oct 8 08:59:35] NOTICE[711] chan_sip.c: -- Registration for '
- Is there something else to enable or a better app to use, for feeding to
broadcastify?
