I am helping work on a machine that I setup with ACID about 7 years ago. The machine that ACID was running on died a few days ago, and we are trying to replace it with a new machine running DIAL.
We got the machine setup without issue, however we are having issues getting DIAL to use the URI (note, this is a URI, not a URIx). We can get audio from Asterisk into the repeater, however we don’t seem to get any audio or COR back from the repeater. The device was 100% working before the machine failed.
As a test, we connected a URIx that we had for another project and that worked without issue. We’re assuming there’s a difference in the URI from the URIx (I know it’s CM108 vs CM119) and the way Asterisk / App_rpt interacts with it.
Anyone able to help with what we need to change to get this working?
I've tested DIAL with both the URI and the URIx. All of my running
nodes that are USB are on the URI. You might try the URI diag. You
will need to build the loopback.
You will also need the software
I should have included it with DIAL.
If you need help with the software, I’ll be happy to help.
73, Steve N4IRS
� I am helping work on a machine that I setup with ACID
machine running DIAL.�
� We got the machine setup without issue, however we are
machine failed.�
� As a test, we connected a URIx that we had for another
CM119) and the way Asterisk / App_rpt interacts with it.�
� Anyone able to help with what we need to change to get
this working?�
73 and thanks,
Matt, NM1B
machine failed.
this working?
73 and thanks,
Matt, NM1B
If you need help with the software, I'll be happy to help.
73, Steve N4IRS
On 1/11/2016 11:02 AM, Matt Brennan
wrote:
Good Day,
machine failed.
this working?
73 and thanks,
Matt, NM1B
